Topic: Terminal block generator Installation
Sorry but  I  don't understand
How to install the plugin? I have python I have the file for the block feature but I don't undertand where to write the command line.
If i do it on cmd it says PYTHON is not a correct app, if I do it on python it says synthax error
Pls help
Re: Terminal block generator Installation
Hello
Can you please give us more detailed information about your Operating system, the text of the error message and so on?
Regards
RedBaron
RedBaron wrote:
Hello
Regards
RedBaron
Hi thanks for the answer
here what I get after I write the command line  pip install --upgrade qet_tb_generator. I hvae python 3.16 (which is the last available pytohon on the site. THis is another strange thing 3.5 is older than 3.1!!!!)
C:\Users\sandr>pip install --upgrade qet_tb_generator
Defaulting to user installation because normal site-packages is not writeable
Requirement already satisfied: qet_tb_generator in c:\users\sandr\appdata\local\packages\pythonsoftwarefoundation.python.3.13_qbz5n2kfra8p0\localcache\local-packages\python313\site-packages (1.3.1)
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x000001E44BFCEA50>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/qet-tb-generator/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x000001E44BF77D90>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/qet-tb-generator/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x000001E44D424050>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/qet-tb-generator/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x000001E44D4242D0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/qet-tb-generator/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x000001E44D424550>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/qet-tb-generator/
Requirement already satisfied: PySimpleGUI in c:\users\sandr\appdata\local\packages\pythonsoftwarefoundation.python.3.13_qbz5n2kfra8p0\localcache\local-packages\python313\site-packages (from qet_tb_generator) (5.0.0.16)
Why don't you just download the binary from github-page and use that?
In that case you do not have to compile it yourself...
https://github.com/raulroda/qet_tb_gene … aster/dist
With a recent 0100-dev - version of QET you find something like this in the log-file
"menu" -> "Help" -> "About QElectroTech" -> tab "Log"
12:35:21.187 Info:  For data-files (user-/company-collections, titleblocks, etc.):
12:35:21.187 Info:  App Data Location: "C:/Tools/qelectrotech/conf"
Use your favorite file-browser to create the subdir "binary" in "App Data Location" and place binary "qet_tb_generator.exe" there.
Then you can use the plugin from QET-Project-Menu.
When starting the plugin, something like this is written to log-file:
12:36:54.665 Info:  project to use for qet_tb_generator:  "C:/Users/ich/Documents/ohne Namen.qet"
12:36:54.665 Info:  qet_tb_generator found here: "C:/Tools/qelectrotech/conf/binary/qet_tb_generator.exe"
Prerequisites for the plugin:
A saved project must be loaded. That project contains terminals that are named according to the scheme “X1:1, X1:2, etc” and are also connected somewhere.
thanks for your help unfortunately still have the same error. Am I aking something wrong? I put the exe file under the bin directory of the qeletrotech folder
Do you have a sample file I can oopen to test it with terminals already done?
thanks
@scerrone
Look for the Example Project "industrial.qet". On Windows it's placed on the File path "C:\Program Files\QElectroTech\examples", on Ubuntu based Linux Distributions on "\usr\share\qelectrotech\examples\ ".
RedBaron wrote:
@scerrone
I have this error anyway
scerrone wrote:
RedBaron wrote:
@scerrone
There is something basic missing ...
What version of QElectroTech do you use?
"menu" -> "Help" -> "About QElectroTech" -> tab "Version"
It seems, you're a new user of QElectroTech:
You should use this (or newer) version to have some additional info in log-file:
https://download.qelectrotech.org/qet/b … 5-02-17-1/
Now to the plugin:
Did you download the exe-file of plugin as suggested from github?
Did you rename the exe-file of plugin to "qet_tb_generator.exe"?
Did you copy the exe-file of plugin to "AppDataLocation"\binary\qet_tb_generator.exe ?
What does the log-file say about "App Data Location"?
What does the log-file say about "qet_tb_generator not found: ..." and "qet_tb_generator found here: ..."
after loading a project and clicking on "menu" -> "Project" -> "Launch the terminal block creation plugin"?
Please answer ALL questions!
Thanks for the help. Now it works. I repeated all and now all is ok. I only have to understand how it works
Thanks for the support
https://qelectrotech.org/forum/viewtopi … 070#p17070
