Topic: Feature request - Copy folio data
Dear All
It would be great if it is possible to copy all folio figures to all folios of the project.
It`s an enormous work to change each flio after some updates.
Thanks.
Greetings
cl
QElectroTech → EN : Help, suggestions, discussions, ... → Feature request - Copy folio data
Dear All
Thanks.
Greetings
cl
Hello Again
Back to this topic.
That`s not what I`m talking about.
I mean not the content ON the foil, but the properties.
For example, if I want to change the revision index on the title block, how can I do this?
If I have 50 foils, I must click through 50 foils?
Thanks
The revision-index is set per folio!
If you want to set all rev-indexes to the same global value, you need to use a project-variable and set this for each folio.
Or use Ctrl +F "search and replace" function.
https://download.qelectrotech.org/qet/m … earch.html
Generated in 0.019 seconds (23% PHP - 77% DB) with 11 queries
