Re: Flatpak packages 0.100-dev
Fixed old url in org.qelectrotech.QElectroTech.flatpakref
Use these to install new devel version:
flatpak remote-delete qelectrotech-origin
flatpak remote-delete qet-devel
flatpak remote-add --gpg-import=public.pgp qet-devel https://download.qelectrotech.org/qet/builds/Flatpak/
flatpak install https://download.qelectrotech.org/qet/builds/Flatpak/org.qelectrotech.QElectroTech.flatpakref
Thank you.
About the pgp file, use the one from earlier in this thread:
wget https://download.qelectrotech.org/qet/builds/Flatpak/public.pgp
flatpak lists the version as 0.9-dev, but the abut box in QET say V 0.100.0-dev
BTW, I moved to 22.3 SDK flatpak..
Fix: Now QET can found and launch qet_tb_generator plugin without scratched under python 3.11 and tkinter.
https://qelectrotech.org/forum/viewtopi … 955#p20955
La mise en route de la Version 1.0 es ultra rapide
Salut Sébastien,
Tu est passé sur linux?
C'est clair que sous linux c'est le jour et la nuit sur la 0.100(dev) 0.3 s contre plusieurs secondes ou longues minutes sous Windows..
Non je suis sur Windows mais je trouve beaucoup plus rapide la 0.100
Si tu veux que ça aille encore plus vite, regarde ici: https://qelectrotech.org/forum/viewtopi … 624#p19624
Flatpak app version is using old runtimes. See bellow:
https://github.com/qelectrotech/qelectr … issues/446
laurent@debian:~$ wget https://download.qelectrotech.org/qet/builds/Flatpak/public.pgp
--2026-04-10 11:40:58--  https://download.qelectrotech.org/qet/builds/Flatpak/public.pgp
Résolution de download.qelectrotech.org (download.qelectrotech.org)… 46.105.204.26
Connexion à download.qelectrotech.org (download.qelectrotech.org)|46.105.204.26|:443… connecté.
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : 3175 (3,1K) [application/pgp-encrypted]
Sauvegarde en : « public.pgp »
public.pgp                  100%[=========================================>]   3,10K  --.-KB/s    ds 0s
2026-04-10 11:40:58 (59,5 MB/s) — « public.pgp » sauvegardé [3175/3175]
laurent@debian:~$ flatpak remote-add --gpg-import=public.pgp qet-devel https://download.qelectrotech.org/qet/builds/Flatpak/
Note that the directories
'/var/lib/flatpak/exports/share'
'/home/laurent/.local/share/flatpak/exports/share'
are not in the search path set by the XDG_DATA_DIRS environment variable, so
applications installed by Flatpak may not appear on your desktop until the
session is restarted.
laurent@debian:~$ flatpak install https://download.qelectrotech.org/qet/builds/Flatpak/org.qelectrotech.QElectroTech.flatpakref
The application org.qelectrotech.QElectroTech depends on runtimes from:
  https://dl.flathub.org/repo/
Configure this as new remote 'flathub' [Y/n]: y
Required runtime for org.qelectrotech.QElectroTech/x86_64/master (runtime/org.kde.Platform/x86_64/5.15-25.08) found in remote flathub
Do you want to install it? [Y/n]: y
org.qelectrotech.QElectroTech permissions:
    ipc       network       cups                 fallback-x11         wayland
    x11       dri           file access [1]      dbus access [2]
    [1] host, xdg-config/kdeglobals:ro
    [2] com.canonical.AppMenu.Registrar, org.kde.KGlobalSettings, org.kde.kconfig.notify
        ID                                         Branch          Op     Remote        Download
 1. [✓] org.freedesktop.Platform.GL.default        25.08           i      flathub       140,4 Mo / 141,4 Mo
 2. [✓] org.freedesktop.Platform.GL.default        25.08-extra     i      flathub        25,2 Mo / 141,4 Mo
 3. [✓] org.freedesktop.Platform.codecs-extra      25.08-extra     i      flathub        14,2 Mo / 14,4 Mo
 4. [✓] org.gtk.Gtk3theme.Breeze                   3.22            i      flathub       114,6 Ko / 192,4 Ko
 5. [✓] org.kde.Platform.Locale                    5.15-25.08      i      flathub         5,6 Mo / 400,3 Mo
 6. [✓] org.kde.Platform                           5.15-25.08      i      flathub       297,0 Mo / 367,4 Mo
 7. [✓] org.qelectrotech.QElectroTech              master          i      qet-devel      21,2 Mo / 31,0 Mo
Installation complete.
QET"s Flatpak repository now updated to Qt 6.11 builds.
laurent@debian:~/qet_git$ flatpak update
Looking for updates…
Required runtime for org.qelectrotech.QElectroTech/x86_64/master (runtime/org.kde.Platform/x86_64/6.11) found in remote flathub
 1. [✓] org.kde.KStyle.Adwaita                  6.11             i            flathub               8,8 MB / 8,8 MB
 2. [✓] org.kde.Platform.Locale                 6.11             i            flathub             564,4 kB / 401,6 MB
 3. [✓] org.kde.Platform                        6.11             i            flathub             328,7 MB / 405,5 MB
 4. [✓] org.qelectrotech.QElectroTech           master           u            qet-devel            14,7 MB / 32,8 MB
Changes complete.
Enjoy! nomicons/wink
