Topic: graphic elements not moving
when selecting multiple elements all elements but the graphic ones do shift.
shooter@home.nl
QElectroTech → FR : Aide, suggestions, discussions, ... → graphic elements not moving
What platform?, in debian, i don't reproduce this problem.
using windows, found some strange behaviour here, while translating i found some type problems as the > was in wrong place.
modified en.ts and nl.ts
as i was searching found the dialog box had french texts, oke so far.
when i locked and again unlocked a shape the shape is not moving until i added another shape.
small bug in software
Please have the shapes also snap on the grid,
Thanks for nl.ts and corrected en.ts.
small bug in softwarefixed :p
Modified: trunk/sources/qetgraphicsitem/qetshapeitem.cpp
--- trunk/sources/qetgraphicsitem/qetshapeitem.cpp 2014-04-28 20:51:23 UTC (rev 3036)
+++ trunk/sources/qetgraphicsitem/qetshapeitem.cpp 2014-04-29 03:47:37 UTC (rev 3037)
@@ -222,6 +222,7 @@
QCheckBox cb(tr("Verrouiller la position"), &property_dialog);
cb.setChecked(!is_movable_);
dialog_layout.addWidget(&cb);
+ cb.setVisible(false);
//dialog button, box
QDialogButtonBox dbb(QDialogButtonBox::Ok | QDialogButtonBox::Cancel);
I think today it is no longer useful to lock shapes.
Now, shapes don't have the focus enabled, when you move element in this or under area.
Generated in 0.023 seconds (28% PHP - 72% DB) with 11 queries
