Topic: Automatic connections
Is there a way of stopping elements connecting to each other when one moved is moved or added?
For example, adding two 16 pin ICs in line results in 8 unwanted connections. You can offset them but that doesn't give a neat result. Thanks.
Re: Automatic connections
Tip: Move the mouse pointer slowly over the icons in the toolbar and read the hint texts!
Found it! Thanks.
