Topic: Importing PDF's of existing prints
Hello
I am just curious to know if it is possible to import an existing PDF of blueprint drawings to make redline updates. I love using this software for new drawings, and I would love to be able to use it to redlines.
Re: Importing PDF's of existing prints
In diagram-editor you can insert pictures.
Convert your pdf to png-images and insert one per folio.
3 (edited by bernard_andre 2024-10-10 13:39:37)
Vous pouvez utiliser QCAD professional ou LibreCAD, ci-joint une exemple commenté fait avec Qelectrotech
You can use QCAD professional or LibreCAD, attached is a commented example made with Qelectrotech
Bernard
Avec Libre office draw c'est plus facile, ouvrir le PDF et l'exporter en SVG.
With Libre office draw it's easier, open the PDF and export it to SVG.
Bernard
