Topic: cable numbers + howto use terminal generator
I managed to use the terminal block generator
the problem I have is that no cables appear  (will be not an issue of the generator, but my lack of knowledge)
the order of the terminals is not as expected
example:
on sheet 4
circuit breaker -9Q2     towards motor -9M1
what to change so that the cable between X1 and the motor -9M1 appears in the terminal block?
also the sequence of the terminals is X1:1,X1:2,X1:3,X1:PE,X1:SH,X1:4,X1:5,X1:6,X1:PE,X1:SH
how to arrange that this order appears in the terminal block?
can you help me on both issues?
Re: cable numbers + howto use terminal generator
BTW, I saw a mistake in your diagram.
https://download.qelectrotech.org/qet/forum_img_2/error_ground.png
ok thanks, mistake corrected,
but that does not solve the issue
any hints how to solve
Use the arrows to move up/down depending on the ranking you want.
Before:
https://download.qelectrotech.org/qet/forum_img_2/terminal_arrows1.png
https://download.qelectrotech.org/qet/forum_img_2/terminal_arrows.png
ok thanks, that solves part of my problem
and now the cable numbering/identification, how to do this?
Read help, see Hose and conductor options.
https://download.qelectrotech.org/qet/forum_img_2/terminal_arrows3.png
https://download.qelectrotech.org/qet/forum_img_2/terminal_arrows4.png
https://download.qelectrotech.org/qet/forum_img_2/terminal_arrows6.png
https://download.qelectrotech.org/qet/forum_img_2/terminal_arrows7.png
https://download.qelectrotech.org/qet/forum_img_2/terminal_arrows8.png
https://download.qelectrotech.org/qet/forum_img_2/terminal_arrows9.png
Thanks for the information,  the help button was not visible because the window was to small
Also I was confused about the word "hose" which in  terms of wiring did not give me a clue
I saw the "cable" column and could not fill anything
now all is clear.
one possible bug:
I filled as you did for testing and it worked
I then closed the application and reopened for filling more information and noticed that the data in fields ID and XREF as example from lines 9 and 10 had been exchanged
any update when this functionality would come into QET itself?
