Topic: problems with uncheck on "apply properties to all conductors of .."
I'm having some problems with unchecking the "apply properties to all conductors of this potential". The uncheck is not recognized. Each time I uncheck it and press OK, and then open the Edit conductor properties of the same conductor again, it is checked again.
Any ideas what could be wrong here? Thank you in advance
Re: problems with uncheck on "apply properties to all conductors of .."
This is the normal behavior, you need to uncheck this button each time you modifie properties and you want this change is applied only for the selected conductor.
