Topic: Help. Convert cade_simu
I've been using CADe_SIMU (V4.0) for some time, but it's very limited and after a lot of research and many compliments I decided to start using QElectroTech.
I didn't want to lose all the work done in CADe_SIMU, could someone help me on how to convert his files to QElectroTech?
I tried using the "DXFtoQET" tool but I couldn't. I don't know if I did something wrong or if the file really isn't compatible with it.
I attached one of my works (it's more of a mess lol) in case you wanted to see the format.
Re: Help. Convert cade_simu
the attached file has the extension .cad, you have to convert it into a DXF file (.dxf) with the program cad simu.
QElectroTech is a program for electrical engineering drawing. No circuit simulations can be made with it.
With best regards
Stebo
I'll try, thank you very much, the program has no other save option, I was able to "print" to pdf and then converted to dwg.
