Topic: character '&'
I am using the current version QElectroTech V 0.90-DEV+5c6b9f182 under linux.
If the character '&' occurs in the declaration of the component name,
then you can no longer drag the component into the drawing.
Is working:
    <names>
        <name lang="de">Klöckner_Möller Zeitrelais TE-69</name>
    </names>
It does not work:
    <names>
        <name lang="de">Klöckner&Möller Zeitrelais TE-69</name>
    </names>
Vbxler
Re: character '&'
I can't reproduce bug. Can you send us the buggy element.
Re: character '&'
here is an example.
Re: character '&'
Did you edit yourself the xml file ? In this case it's normal you should write &amp; instead of only &.
https://stackoverflow.com/questions/311 … amp-in-xml
Re: character '&'
Yes, I edited the file by hand.
That's where the error came from.
Sorry for the inconvenience caused by my mistake.
