Topic: New versiónavailable (1.3.0)
Hi, this new version support the new QET could use to define what a cable is connected to.
Now supports if a cable is linked using the Terminalid XML property (as before) or using the UUID of the element.
The new version is availabe as python pip package , or a portable executables at https://github.com/raulroda/qet_tb_gene … aster/dist
Re: New versiónavailable (1.3.0)
https://www.pythonguis.com/tutorials/pa … macos-dmg/
macOS qet_tb_generator portable executable version:
https://download.tuxfamily.org/qet/buil … _generator
Bundle :
https://download.tuxfamily.org/qet/buil … or.app.zip
Python 3.10 on Debian Unstable break qet_tb_generator :
AttributeError: module 'enum' has no attribute '_simple_enum'
qet_tb_generator
  File "/usr/bin/qet_tb_generator", line 33, in <module>
    sys.exit(load_entry_point('qet-tb-generator==1.3.1', 'console_scripts', 'qet_tb_generator')())
  File "/usr/bin/qet_tb_generator", line 25, in importlib_load_entry_point
    return next(matches).load()
  File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 171, in load
    module = import_module(match.group('module'))
  File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/usr/lib/python3/dist-packages/src/main.py", line 98, in <module>
    import src.PySimpleGUI as sg
  File "/usr/lib/python3/dist-packages/src/PySimpleGUI.py", line 95, in <module>
    import tkinter as tk
  File "/usr/lib/python3.10/tkinter/__init__.py", line 147, in <module>
    @enum._simple_enum(enum.StrEnum)
Workaround is to remove my package and use standalone python qet_tb_generator package on your ~/.qet directory
https://download.tuxfamily.org/qet/buil … .3.0_linux
off course rename it to qet_tb_generator.
