Topic: save project as read only
Hi
trying to find if it is possible to save a project as read only in the software ?
QElectroTech → EN : Help, suggestions, discussions, ... → save project as read only
Hi
not for now, abandoned feature:
https://qelectrotech.org/forum/viewtopic.php?id=997
We believe as part of the free software movement that if you need to encrypt your projects, there is plenty of libre software or not to do so, it is not up to us to deal with the decryption problems that might arise.
BTW, on linux you can use The chattr command.
Otherwise a possible solution :
https://wiki.qt.io/Simple_encryption_with_SimpleCrypt
https://github.com/bricke/Qt-AES
https://forum.qt.io/topic/111294/encryp … -in-qt-how
BTW on Linux you could use
sudo chattr +a your_project.qetUser can navigate on project, use link with folio reports, XRefs.., etc, but can't modify it without root password system.
https://www.unixmen.com/secure-and-prev … th-chattr/
Generated in 0.018 seconds (24% PHP - 76% DB) with 11 queries
