Topic: cntrl + not working in last linux update - Date : Apr 25 2022 : 16:49:
Control + is not woking in the last update 0.90-DEV+17290ae3bb0a58100c957a06d79751d3.
Commnad zoom in is working.
QElectroTech → EN : Help, suggestions, discussions, ... → cntrl + not working in last linux update - Date : Apr 25 2022 : 16:49:
Strange! ctrl +/- work here on my Debian Sid with
QElectroTech V 0.90-DEV+17290ae3bb0a58100c957a06d79751d3
Compilation : GCC 11.2.0
Built with Qt 5.15.2 - Date : Apr 25 2022 : 16:44:31
Run with Qt 5.15.2 using 48 thread(s)
CPU : model name : AMD Ryzen Threadripper 3960X 24-Core Processor
RAM Total : 64257 MB
RAM Available : 59532 MB
GPU : Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7)
GPU RAM : Video memory: 4096MB Dedicated video memory: 4096 MB Currently available dedicated video memory: 3086 MB
OS : linux - x86_64 - Version : Debian GNU/Linux bookworm/sid - Kernel : 5.17.4-vanilla
*** Qt screens ***
( 1 : 3840 x 2160 )
( 2 : 1920 x 1080 )
I changed the distribution to impish.
Could be it the reason?
https://ppa.launchpadcontent.net/scorpi … ev/ubuntu/
impish
main
Today another version:
QElectroTech V 0.90-DEV+34a7e0f3fb0a58100c957a06d79751d3
Built with Qt 5.15.2 - Date : Apr 26 2022 : 06:01:50
Run with Qt 5.15.3 using 4 thread(s)
CPU : model name : Intel(R) Core(TM) i5-4300U CPU @ 1.90GHz
RAM Total : 7 GB
RAM Available : 6 GB
GPU : Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
GPU RAM : Video memory: 1536MB
OS : linux - x86_64 - Version : Ubuntu 22.04 LTS - Kernel : 5.15.0-27-generic
*** Qt screens ***
( 1 : 1920 x 1080 )
I changed to jammy.
Same problem.
you could try with sudo evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: Logitech K540/K545
/dev/input/event1: Logitech M510
/dev/input/event2: Generic USB Audio Consumer Control
/dev/input/event3: Generic USB Audio
/dev/input/event4: MSI MYSTIC LIGHT
/dev/input/event5: Power Button
/dev/input/event6: Power Button
/dev/input/event7: PC Speaker
/dev/input/event8: HDA ATI HDMI HDMI/DP,pcm=3
/dev/input/event9: HDA ATI HDMI HDMI/DP,pcm=7
/dev/input/event10: HDA ATI HDMI HDMI/DP,pcm=8
/dev/input/event11: HDA ATI HDMI HDMI/DP,pcm=9
/dev/input/event12: HDA ATI HDMI HDMI/DP,pcm=10
Select the device event number [0-12]: 0
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x46d product 0x4076 version 0x111
Input device name: "Logitech K540/K545"
Testing ... (interrupt to exit)
Event: time 1650980111.940440, type 17 (EV_LED), code 0 (LED_NUML), value 0
Event: time 1650980111.940440, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70028
Event: time 1650980111.940440, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1650980111.940440, -------------- SYN_REPORT ------------
Event: time 1650980115.204108, type 4 (EV_MSC), code 4 (MSC_SCAN), value 700e0
Event: time 1650980115.204108, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1650980115.204108, -------------- SYN_REPORT ------------
Event: time 1650980115.372100, type 4 (EV_MSC), code 4 (MSC_SCAN), value 700e0
Event: time 1650980115.372100, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 0
Event: time 1650980115.372100, -------------- SYN_REPORT ------------
Event: time 1650980119.741677, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70057
Event: time 1650980119.741677, type 1 (EV_KEY), code 78 (KEY_KPPLUS), value 1
Event: time 1650980119.741677, -------------- SYN_REPORT ------------
+Event: time 1650980119.827671, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70057
Event: time 1650980119.827671, type 1 (EV_KEY), code 78 (KEY_KPPLUS), value 0
Event: time 1650980119.827671, -------------- SYN_REPORT ------------
Event: time 1650980127.310971, type 4 (EV_MSC), code 4 (MSC_SCAN), value 700e0
Event: time 1650980127.310971, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1650980127.310971, -------------- SYN_REPORT ------------
Event: time 1650980127.578685, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1650980127.578685, -------------- SYN_REPORT ------------
Event: time 1650980127.618684, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1650980127.618684, -------------- SYN_REPORT ------------
Event: time 1650980127.658684, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1650980127.658684, -------------- SYN_REPORT ------------
Event: time 1650980127.698686, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 2
Event: time 1650980127.698686, -------------- SYN_REPORT ------------
-Event: time 1650980334.123792, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70056
Event: time 1650980334.123792, type 1 (EV_KEY), code 74 (KEY_KPMINUS), value 0
Event: time 1650980334.123792, -------------- SYN_REPORT ------------
toor@toor-Latitude-E7440:~$ sudo evtest
Available devices:
/dev/input/event0: Lid Switch
/dev/input/event1: Power Button
/dev/input/event2: Sleep Button
/dev/input/event3: Power Button
/dev/input/event4: AT Translated Set 2 keyboard
/dev/input/event5: USB OPTICAL MOUSE
/dev/input/event6: AlpsPS/2 ALPS DualPoint Stick
/dev/input/event7: AlpsPS/2 ALPS DualPoint TouchPad
/dev/input/event8: Dell WMI hotkeys
/dev/input/event9: HDA Intel PCH Dock Mic
/dev/input/event10: HDA Intel PCH Dock Line Out
/dev/input/event11: HDA Intel PCH Front Headphone
/dev/input/event12: Video Bus
/dev/input/event13: HDA Intel HDMI HDMI/DP,pcm=3
/dev/input/event14: HDA Intel HDMI HDMI/DP,pcm=7
/dev/input/event15: HDA Intel HDMI HDMI/DP,pcm=8
/dev/input/event16: HDA Intel HDMI HDMI/DP,pcm=9
/dev/input/event17: HDA Intel HDMI HDMI/DP,pcm=10
Select the device event number [0-17]: 5
Input device ID: bus 0x3 vendor 0x275d product 0xba6 version 0x111
Input device name: "USB OPTICAL MOUSE "
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 272 (BTN_LEFT)
Event code 273 (BTN_RIGHT)
Event code 274 (BTN_MIDDLE)
Event type 2 (EV_REL)
Event code 0 (REL_X)
Event code 1 (REL_Y)
Event code 8 (REL_WHEEL)
Event code 11 (REL_WHEEL_HI_RES)
Event type 4 (EV_MSC)
Event code 4 (MSC_SCAN)
Properties:
Event: time 1650981988.889948, type 2 (EV_REL), code 0 (REL_X), value -1
Event: time 1650981988.889948, type 2 (EV_REL), code 1 (REL_Y), value -1
Event: time 1650981988.889948, -------------- SYN_REPORT ------------
Event: time 1650981988.905946, type 2 (EV_REL), code 0 (REL_X), value -1
Event: time 1650981988.905946, type 2 (EV_REL), code 1 (REL_Y), value -3
Event: time 1650981988.905946, -------------- SYN_REPORT ------------
Event: time 1650981988.913943, type 2 (EV_REL), code 0 (REL_X), value -3
Event: time 1650981988.913943, type 2 (EV_REL), code 1 (REL_Y), value -4
Select 4 AT Translated Set 2 keyboard
For zoom in/out you could use keyboard ctrl + +/- keys, and or mouse roller, or multi-gesture on your touchpad (Pinch-to-zoom, etc ..) if you enable it in config.
Available devices:
Select the device event number [0-17]: 4
Input device ID: bus 0x11 vendor 0x1 product 0x1 version 0xab41
Input device name: "AT Translated Set 2 keyboard"
Supported events:
Event code 1 (KEY_ESC)
Event code 2 (KEY_1)
Event code 3 (KEY_2)
Event code 4 (KEY_3)
Event code 5 (KEY_4)
Event code 6 (KEY_5)
Event code 7 (KEY_6)
Event code 8 (KEY_7)
Event code 9 (KEY_8)
Event code 10 (KEY_9)
Event code 11 (KEY_0)
Event code 12 (KEY_MINUS)
Event code 13 (KEY_EQUAL)
Event code 14 (KEY_BACKSPACE)
Event code 15 (KEY_TAB)
Event code 16 (KEY_Q)
Event code 17 (KEY_W)
Event code 18 (KEY_E)
Event code 19 (KEY_R)
Event code 20 (KEY_T)
Event code 21 (KEY_Y)
Event code 22 (KEY_U)
Event code 23 (KEY_I)
Event code 24 (KEY_O)
Event code 25 (KEY_P)
Event code 26 (KEY_LEFTBRACE)
Event code 27 (KEY_RIGHTBRACE)
Event code 28 (KEY_ENTER)
Event code 29 (KEY_LEFTCTRL)
Event code 30 (KEY_A)
Event code 31 (KEY_S)
Event code 32 (KEY_D)
Event code 33 (KEY_F)
Event code 34 (KEY_G)
Event code 35 (KEY_H)
Event code 36 (KEY_J)
Event code 37 (KEY_K)
Event code 38 (KEY_L)
Event code 39 (KEY_SEMICOLON)
Event code 40 (KEY_APOSTROPHE)
Event code 41 (KEY_GRAVE)
Event code 42 (KEY_LEFTSHIFT)
Event code 43 (KEY_BACKSLASH)
Event code 44 (KEY_Z)
Event code 45 (KEY_X)
Event code 46 (KEY_C)
Event code 47 (KEY_V)
Event code 48 (KEY_B)
Event code 49 (KEY_N)
Event code 50 (KEY_M)
Event code 51 (KEY_COMMA)
Event code 52 (KEY_DOT)
Event code 53 (KEY_SLASH)
Event code 54 (KEY_RIGHTSHIFT)
Event code 55 (KEY_KPASTERISK)
Event code 56 (KEY_LEFTALT)
Event code 57 (KEY_SPACE)
Event code 58 (KEY_CAPSLOCK)
Event code 59 (KEY_F1)
Event code 60 (KEY_F2)
Event code 61 (KEY_F3)
Event code 62 (KEY_F4)
Event code 63 (KEY_F5)
Event code 64 (KEY_F6)
Event code 65 (KEY_F7)
Event code 66 (KEY_F8)
Event code 67 (KEY_F9)
Event code 68 (KEY_F10)
Event code 69 (KEY_NUMLOCK)
Event code 70 (KEY_SCROLLLOCK)
Event code 71 (KEY_KP7)
Event code 72 (KEY_KP8)
Event code 73 (KEY_KP9)
Event code 74 (KEY_KPMINUS)
Event code 75 (KEY_KP4)
Event code 76 (KEY_KP5)
Event code 77 (KEY_KP6)
Event code 78 (KEY_KPPLUS)
Event code 79 (KEY_KP1)
Event code 80 (KEY_KP2)
Event code 81 (KEY_KP3)
Event code 82 (KEY_KP0)
Event code 83 (KEY_KPDOT)
Event code 85 (KEY_ZENKAKUHANKAKU)
Event code 86 (KEY_102ND)
Event code 87 (KEY_F11)
Event code 88 (KEY_F12)
Event code 89 (KEY_RO)
Event code 90 (KEY_KATAKANA)
Event code 91 (KEY_HIRAGANA)
Event code 92 (KEY_HENKAN)
Event code 93 (KEY_KATAKANAHIRAGANA)
Event code 94 (KEY_MUHENKAN)
Event code 95 (KEY_KPJPCOMMA)
Event code 96 (KEY_KPENTER)
Event code 97 (KEY_RIGHTCTRL)
Event code 98 (KEY_KPSLASH)
Event code 99 (KEY_SYSRQ)
Event code 100 (KEY_RIGHTALT)
Event code 102 (KEY_HOME)
Event code 103 (KEY_UP)
Event code 104 (KEY_PAGEUP)
Event code 105 (KEY_LEFT)
Event code 106 (KEY_RIGHT)
Event code 107 (KEY_END)
Event code 108 (KEY_DOWN)
Event code 109 (KEY_PAGEDOWN)
Event code 110 (KEY_INSERT)
Event code 111 (KEY_DELETE)
Event code 112 (KEY_MACRO)
Event code 113 (KEY_MUTE)
Event code 114 (KEY_VOLUMEDOWN)
Event code 115 (KEY_VOLUMEUP)
Event code 116 (KEY_POWER)
Event code 117 (KEY_KPEQUAL)
Event code 118 (KEY_KPPLUSMINUS)
Event code 119 (KEY_PAUSE)
Event code 121 (KEY_KPCOMMA)
Event code 122 (KEY_HANGUEL)
Event code 123 (KEY_HANJA)
Event code 124 (KEY_YEN)
Event code 125 (KEY_LEFTMETA)
Event code 126 (KEY_RIGHTMETA)
Event code 127 (KEY_COMPOSE)
Event code 128 (KEY_STOP)
Event code 140 (KEY_CALC)
Event code 141 (KEY_SETUP)
Event code 142 (KEY_SLEEP)
Event code 143 (KEY_WAKEUP)
Event code 148 (KEY_PROG1)
Event code 152 (KEY_SCREENLOCK)
Event code 155 (KEY_MAIL)
Event code 156 (KEY_BOOKMARKS)
Event code 157 (KEY_COMPUTER)
Event code 158 (KEY_BACK)
Event code 159 (KEY_FORWARD)
Event code 162 (KEY_EJECTCLOSECD)
Event code 163 (KEY_NEXTSONG)
Event code 164 (KEY_PLAYPAUSE)
Event code 165 (KEY_PREVIOUSSONG)
Event code 166 (KEY_STOPCD)
Event code 172 (KEY_HOMEPAGE)
Event code 173 (KEY_REFRESH)
Event code 183 (KEY_F13)
Event code 184 (KEY_F14)
Event code 185 (KEY_F15)
Event code 191 (KEY_F21)
Event code 205 (KEY_SUSPEND)
Event code 212 (KEY_CAMERA)
Event code 215 (KEY_EMAIL)
Event code 217 (KEY_SEARCH)
Event code 224 (KEY_BRIGHTNESSDOWN)
Event code 225 (KEY_BRIGHTNESSUP)
Event code 226 (KEY_MEDIA)
Event code 227 (KEY_SWITCHVIDEOMODE)
Event code 236 (KEY_BATTERY)
Event code 240 (KEY_UNKNOWN)
Event type 17 (EV_LED)
Event code 0 (LED_NUML) state 0
Event code 1 (LED_CAPSL) state 0
Event code 2 (LED_SCROLLL) state 0
Key repeat handling:
Repeat type 20 (EV_REP)
Repeat code 0 (REP_DELAY)
Value 250
Repeat code 1 (REP_PERIOD)
Value 33
Properties:
Event: time 1650983045.461066, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c
Event: time 1650983045.461066, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1650983045.461066, -------------- SYN_REPORT ------------
Select gesture for touchpad
https://download.qelectrotech.org/qet/m … rance.html
Keyboard movements
https://download.qelectrotech.org/qet/m … _grid.html
In my case:
unchecked: use gestures touchpad
mouse roller is woking.
It is enough!
control + is working in the last version:
Date : Apr 28 2022 : 13:19:13
QElectroTech V 0.90-DEV+e1865fec6b0a58100c957a06d79751d3
Thanks for your feedback.
Generated in 0.185 seconds (90% PHP - 10% DB) with 11 queries
