@alexhaasjogos, thanks.
SSD/sata/or pciE or HD?
if you have a hard drive it's probably normal to have these load times, but I saw a big progress with latest Windows update..
QElectroTech → News → Nouveautés de la version de développement 0.9> 0.200.1
Running on an i5 notebook, with HD.
But it's worth noting that this happens on the first boot. If you exit oand enter, or an error occurs, it used to take the same time or more. Not now, it only takes about 40 seconds to reload.
Note that I only measure the first boot, once Windows has started. The other throws after are much faster.
On my laptop is a SSD NVME PCIE 3x.
FYI:
On My Debian machine SSD NVME PCIE 3x.
14:15:48.103 Info: Start-up 14:15:48.157 Info: debugging enabled: false 14:15:48.158 Info: Qt library version: 5.15.2 14:15:48.158 Info: Qt library location default prefix: "/usr" 14:15:48.158 Info: Qt library location documentation: "/usr/share/qt5/doc" 14:15:48.158 Info: Qt library location headers: "/usr/include/x86_64-linux-gnu/qt5" 14:15:48.158 Info: Qt library location libraries: "/usr/lib/x86_64-linux-gnu" 14:15:48.158 Info: Qt library location executables: "/usr/lib/x86_64-linux-gnu/qt5/libexec" 14:15:48.158 Info: Qt library location Qt binaries: "/usr/lib/qt5/bin" 14:15:48.158 Info: Qt library location Qt plugins: "/usr/lib/x86_64-linux-gnu/qt5/plugins" 14:15:48.158 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/imports" 14:15:48.158 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/qml" 14:15:48.158 Info: Qt library location dependent Qt data: "/usr/lib/x86_64-linux-gnu/qt5" 14:15:48.158 Info: Qt library location independent Qt data: "/usr/share/qt5" 14:15:48.158 Info: Qt library location translation: "/usr/share/qt5/translations" 14:15:48.158 Info: Qt library location examples: "/usr/lib/x86_64-linux-gnu/qt5/examples" 14:15:48.158 Info: Qt library location Qt testcases: "/usr/tests" 14:15:48.158 Info: Qt library location Qt settings: "/etc/xdg" 14:15:48.158 Info: "QElectroTech V 0.90-DEV+f08811acab0a58100c957a06d79751d3" 14:15:48.158 Info: "Compilation: GCC 11.2.0" 14:15:48.158 Info: "Built with Qt 5.15.2 - Date : Nov 7 2021 : 11:58:58" 14:15:48.158 Info: "Run with Qt 5.15.2 using 48 thread(s)" 14:15:48.158 Info: "CPU : model name\t: AMD Ryzen Threadripper 3960X 24-Core Processor\n" 14:15:48.158 Info: "RAM Total : 64193 MB" 14:15:48.158 Info: "RAM Available : 59416 MB" 14:15:48.158 Info: "GPU : Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7)\n" 14:15:48.158 Info: "GPU RAM : @ToDo" 14:15:48.158 Info: "OS : linux - x86_64 - Version : Debian GNU/Linux bookworm/sid - Kernel : 5.15.4-vanilla" 14:15:48.158 Info: *** Qt screens *** 14:15:48.158 Info: "( 1 : 3840 x 2160 )" 14:15:48.158 Info: "( 2 : 1920 x 1080 )" 14:15:48.412 Info: Elements collection reload 14:15:48.701 Info: Elements collection finished to be loaded./count_elements.sh
7820 elements dans 1039 categories (soit 8859 fichiers)14:15:48.103 Info: Start-up
14:15:48.701 Info: Elements collection finished to be loaded7820 elements loaded in 0.3 seconds .... 0.6 seconds after click to launch QET is ready.
@Joshua FTBFS on Debian Stable Bullseye.. ![]()
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/gridlayoutanimation.o sources/titleblock/gridlayoutanimation.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/helpercell.o sources/titleblock/helpercell.cpp
sources/qetxml.cpp: In function 'bool QETXML::validXmlProperty(const QDomElement&)':
sources/qetxml.cpp:917:5: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if (!e.hasAttribute("value"))
sources/qetxml.cpp:920:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the 'if'
return true;
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/integrationmovetemplateshandler.o sources/titleblock/integrationmovetemplateshandler.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/qettemplateeditor.o sources/titleblock/qettemplateeditor.cpp
In file included from /usr/include/x86_64-linux-gnu/qt5/QtCore/qglobal.h:105,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/qeasingcurve.h:43,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/qvariantanimation.h:43,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/qpropertyanimation.h:43,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/QPropertyAnimation:1,
from sources/SearchAndReplace/ui/../../QWidgetAnimation/qwidgetanimation.h:21,
from sources/SearchAndReplace/ui/searchandreplacewidget.h:21,
from sources/qetdiagrameditor.h:21,
from sources/qetdiagrameditor.cpp:18:
/usr/include/x86_64-linux-gnu/qt5/QtCore/qhashfunctions.h: In instantiation of 'uint qHash(const T&, uint) [with T = std::nullptr_t; uint = unsigned int]':
sources/TerminalStrip/ui/terminalstripmodel.h:41:29: required from here
/usr/include/x86_64-linux-gnu/qt5/QtCore/qhashfunctions.h:112:5: error: call of overloaded 'qHash(std::nullptr_t&)' is ambiguous
Q_DECL_NOEXCEPT_EXPR(noexcept(qHash(t)))
In file included from /usr/include/x86_64-linux-gnu/qt5/QtCore/qlist.h:47,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/qvector.h:45,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/qeasingcurve.h:45,
/usr/include/x86_64-linux-gnu/qt5/QtCore/qhashfunctions.h:97:41: note: candidate: 'uint qHash(const QByteArray&, uint)'
Q_CORE_EXPORT Q_DECL_PURE_FUNCTION uint qHash(const QByteArray &key, uint seed = 0) Q_DECL_NOTHROW;
/usr/include/x86_64-linux-gnu/qt5/QtCore/qhashfunctions.h:99:41: note: candidate: 'uint qHash(const QString&, uint)'
Q_CORE_EXPORT Q_DECL_PURE_FUNCTION uint qHash(const QString &key, uint seed = 0) Q_DECL_NOTHROW;
/usr/include/x86_64-linux-gnu/qt5/QtCore/qhashfunctions.h:100:41: note: candidate: 'uint qHash(const QStringRef&, uint)'
Q_CORE_EXPORT Q_DECL_PURE_FUNCTION uint qHash(const QStringRef &key, uint seed = 0) Q_DECL_NOTHROW;
/usr/include/x86_64-linux-gnu/qt5/QtCore/qhashfunctions.h:102:41: note: candidate: 'uint qHash(QStringView, uint)'
Q_CORE_EXPORT Q_DECL_PURE_FUNCTION uint qHash(QStringView key, uint seed = 0) Q_DECL_NOTHROW;
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/splittedhelpercell.o sources/titleblock/splittedhelpercell.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/templatecellsset.o sources/titleblock/templatecellsset.cpp
/usr/include/x86_64-linux-gnu/qt5/QtCore/qhashfunctions.h:113:15: error: call of overloaded 'qHash(std::nullptr_t&)' is ambiguous
{ return qHash(t) ^ seed; }
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/templatecellwidget.o sources/titleblock/templatecellwidget.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/templatecommands.o sources/titleblock/templatecommands.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/templatedeleter.o sources/titleblock/templatedeleter.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/templatelocation.o sources/titleblock/templatelocation.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/templatelocationchooser.o sources/titleblock/templatelocationchooser.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7512=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/templatelocationsaver.o sources/titleblock/templatelocationsaver.cpp
make[2]: *** [Makefile.Release:5134: release/qetdiagrameditor.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory '/build/qelectrotech-0.90.r7512'
make[1]: *** [Makefile:40: release] Error 2
make[1]: Leaving directory '/build/qelectrotech-0.90.r7512'
dh_auto_build: make -j48 returned exit code 2
make: *** [debian/rules:8: binary] Error 2
dpkg-buildpackage: error: debian/rules binary subprocess returned exit status 2
I: copying local configuration
E: Failed autobuilding of package
I: unmounting dev/ptmx filesystem
I: unmounting dev/pts filesystem
I: unmounting proc filesystem
I: unmounting sys filesystem
I: cleaning the build env
I: removing directory /var/cache/pbuilder/build//43634 and its subdirectories
Same on ubuntu-bionic and ubuntu-focal ...
https://launchpadlibrarian.net/58264754 … ING.txt.gz
https://launchpadlibrarian.net/58264751 … ING.txt.gz
https://launchpadlibrarian.net/58264725 … ING.txt.gz
Rejected:
hirsute is obsolete and will not accept new uploads.qelectrotech (0.90.r7512-2ubuntu3) hirsute; urgency=medium
I can't produce these build on my PPA to Hirsute., please upgrade... to new ubuntu version, thanks.
scorpio810 wrote:scorpio810 wrote:Due to the complete migration of the site to PHP 7.x instead off PHP 5.x I intend to completely delete the online viewer elmt to SVG..
These old PHP scripts need to be rewritten completely for migrating from PHP 5.6.x to PHP 7.0.x, and I do not have the time or the knowledge of a PHP expert.
https://www.php.net/migration70FYI, PunBB forum, Dokuwiki, Mantis Bugtracker, now run on PHP 7. And Mantis was upgraded on 2.X branch.
On Forum I removed old plugin SC WYSIWYG BBCode editor, so we have come back on the official BBcode but on the other hand the other BBcode even if it was more complete was a source of bugs during posts editions, and has force of hacks the PunBB now works with PHP 7 without empty messages on the forum.If a PHP expert can help us, I'm ready to send him the old PHP files.
BTW, will have the opportunity to move to the new site and find a way to generate another SVG online viewer from the item collection.
Seny a retravaillé les scripts PHP 5 pour les rendrent compatible PHP 7/8 ..pour qu'ils soit de nouveau possible d'avoir la collection officielle en visuel en convertissant les éléments "elmt" en fichiers SVG sur le site Web à la volée (online viewer elmt to SVG) .
Çà du être un gros labeur et AMHA surement semé d’embûches, on ne peut que le remercier.
commit d562ca8a3954ee47534e0c3f82683a65200b8bb1
Author: joshua <Joshua@q>
Date: Fri Jan 28 18:08:16 2022 +0100
Fix fail to build from sources
commit a31bd6eb0da59d946c011d5bad1abb783d36825a
Author: joshua <Joshua@>
Date: Thu Jan 27 20:00:46 2022 +0100
Minor improvement about undo/redo for bridge creation
When a new bridge is created, an undo command is created for that.
When undo the action and redo it, all terminals are bridged to a new
bridge instead of the first one, who continue to exist but is now
empty and 'lost' because he will never be reused.
In addition of that, if a more recent undo command (we call it undo2)
use this bridge,
there is a unknown behavior, because the status of the bridge is not the
same as when the undo2 was created.
commit d114b097bf001c452e856dbf356c99de009a5931
Date: Thu Jan 27 19:45:33 2022 +0100
Minor Fix : undo command for unbridge strip don't work
commit 993eb58d467fc3d0d8775932ed895f853d0c9898
Date: Thu Jan 27 19:07:49 2022 +0100
Minor : add undo text
commit 0bd0476cb1aa4b72c118f2750ea53e1155a6dc56
Merge: 7aa0487 d562ca8
Date: Fri Jan 28 18:09:20 2022 +0100
Merge branch 'terminal_strip'
* terminal_strip:
@Joshua, not fixed yet here.. Debian Bullseye, Ubuntu Bionic, and Focal...
In file included from sources/TerminalStrip/physicalterminal.cpp:18:
sources/TerminalStrip/physicalterminal.h:91:41: error: field 'm_real_terminal' has incomplete type 'QVector<QSharedPointer<RealTerminal> >'
QVector<QSharedPointer<RealTerminal>> m_real_terminal;
In file included from /usr/include/x86_64-linux-gnu/qt5/QtCore/qglobal.h:1194,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/qsharedpointer.h:43,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/QSharedPointer:1,
from sources/TerminalStrip/physicalterminal.h:21,
/usr/include/x86_64-linux-gnu/qt5/QtCore/qtypeinfo.h:193:1: note: declaration of 'class QVector<QSharedPointer<RealTerminal> >'
Q_DECLARE_MOVABLE_CONTAINER(QVector);
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7517=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/groupterminalscommand.o sources/TerminalStrip/UndoCommand/groupterminalscommand.cpp
In file included from sources/TerminalStrip/terminalstripbridge.cpp:18:
sources/TerminalStrip/terminalstripbridge.h:51:41: error: field 'm_real_terminals' has incomplete type 'QVector<QSharedPointer<RealTerminal> >'
QVector<QSharedPointer<RealTerminal>> m_real_terminals;
from sources/TerminalStrip/terminalstripbridge.h:21,
sources/TerminalStrip/terminalstripbridge.h:34:40: error: return type 'class QVector<QColor>' is incomplete
static QVector<QColor> bridgeColor() {return QVector<QColor>{Qt::red, Qt::blue, Qt::white, Qt::darkGray, Qt::black};}
sources/TerminalStrip/terminalstripbridge.h: In static member function 'static void TerminalStripBridge::bridgeColor()':
sources/TerminalStrip/terminalstripbridge.h:34:117: error: too many initializers for 'QVector<QColor>'
In file included from sources/TerminalStrip/UndoCommand/changeterminalstripcolor.cpp:19:
sources/TerminalStrip/UndoCommand/../terminalstripbridge.h:51:41: error: field 'm_real_terminals' has incomplete type 'QVector<QSharedPointer<RealTerminal> >'
from /usr/include/x86_64-linux-gnu/qt5/QtGui/qtguiglobal.h:43,
from /usr/include/x86_64-linux-gnu/qt5/QtWidgets/qtwidgetsglobal.h:43,
from /usr/include/x86_64-linux-gnu/qt5/QtWidgets/qundostack.h:43,
from /usr/include/x86_64-linux-gnu/qt5/QtWidgets/QUndoCommand:1,
from sources/TerminalStrip/UndoCommand/changeterminalstripcolor.h:21,
from sources/TerminalStrip/UndoCommand/changeterminalstripcolor.cpp:18:
sources/TerminalStrip/UndoCommand/../terminalstripbridge.h:34:40: error: return type 'class QVector<QColor>' is incomplete
sources/TerminalStrip/UndoCommand/../terminalstripbridge.h: In static member function 'static void TerminalStripBridge::bridgeColor()':
sources/TerminalStrip/UndoCommand/../terminalstripbridge.h:34:117: error: too many initializers for 'QVector<QColor>'
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7517=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -Isources/TerminalStrip/ui -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtSql -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o release/sortterminalstripcommand.o sources/TerminalStrip/UndoCommand/sortterminalstripcommand.cpp
make[2]: *** [Makefile.Release:9843: release/changeterminalstripcolor.o] Error 1
make[2]: *** [Makefile.Release:9606: release/physicalterminal.o] Error 1
make[2]: *** [Makefile.Release:9668: release/terminalstripbridge.o] Error 1
make[2]: Leaving directory '/build/qelectrotech-0.90.r7517'
make[1]: Leaving directory '/build/qelectrotech-0.90.r7517'
I: removing directory /var/cache/pbuilder/build//76724 and its subdirectories
https://launchpadlibrarian.net/58265413 … ING.txt.gz
https://launchpadlibrarian.net/58265436 … ING.txt.gz
With new version the time to finish is very good :
07:45:57.681 Info: "( 1 : 1366 x 768 )"
07:46:31.232 Info: Elements collection finished to be loaded
with 9093 elements.
Good day!
commit 1a26133a7803f74d9297bd25abb3549f957d17ce
Date: Sun Feb 6 15:50:25 2022 +0100
Add a QElapsedTimer to compute time used for reload element collection
Au moins plus besoin de sortir la calculette pour mesurer :p
J'en ai profiter pour tester sur mes différents builds et packages les differences.
On commence par la Workstation en Debian Sid, dernier kernel tout frais compilé
SSD NVME PCIE 3X:
16:09:48.497 Info: Start-up
16:09:48.498 Debug: "File /home/test/.qet/20211126.log is deleted!" (sources/main.cpp:150, void delete_old_log_files(int))
16:09:48.558 Info: debugging enabled: false
16:09:48.558 Info: Qt library version: 5.15.2
16:09:48.558 Info: Qt library location default prefix: "/usr"
16:09:48.558 Info: Qt library location documentation: "/usr/share/qt5/doc"
16:09:48.558 Info: Qt library location headers: "/usr/include/x86_64-linux-gnu/qt5"
16:09:48.558 Info: Qt library location libraries: "/usr/lib/x86_64-linux-gnu"
16:09:48.558 Info: Qt library location executables: "/usr/lib/x86_64-linux-gnu/qt5/libexec"
16:09:48.558 Info: Qt library location Qt binaries: "/usr/lib/qt5/bin"
16:09:48.558 Info: Qt library location Qt plugins: "/usr/lib/x86_64-linux-gnu/qt5/plugins"
16:09:48.558 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/imports"
16:09:48.558 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/qml"
16:09:48.558 Info: Qt library location dependent Qt data: "/usr/lib/x86_64-linux-gnu/qt5"
16:09:48.558 Info: Qt library location independent Qt data: "/usr/share/qt5"
16:09:48.558 Info: Qt library location translation: "/usr/share/qt5/translations"
16:09:48.558 Info: Qt library location examples: "/usr/lib/x86_64-linux-gnu/qt5/examples"
16:09:48.558 Info: Qt library location Qt testcases: "/usr/tests"
16:09:48.558 Info: Qt library location Qt settings: "/etc/xdg"
16:09:48.558 Info: "QElectroTech V 0.90-DEV+1a26133a7b0a58100c957a06d79751d3"
16:09:48.558 Info: "Compilation: GCC 11.2.0"
16:09:48.558 Info: "Built with Qt 5.15.2 - Date : Feb 6 2022 : 14:52:54"
16:09:48.558 Info: "Run with Qt 5.15.2 using 48 thread(s)"
16:09:48.558 Info: "CPU : model name\t: AMD Ryzen Threadripper 3960X 24-Core Processor\n"
16:09:48.558 Info: "RAM Total : 64257 MB"
16:09:48.558 Info: "RAM Available : 57433 MB"
16:09:48.558 Info: "GPU : Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7)\n"
16:09:48.558 Info: "GPU RAM : @ToDo"
16:09:48.558 Info: "OS : linux - x86_64 - Version : Debian GNU/Linux bookworm/sid - Kernel : 5.16.7-vanilla"
16:09:48.558 Info: *** Qt screens ***
16:09:48.558 Info: "( 1 : 3840 x 2160 )"
16:09:48.559 Info: "( 2 : 1920 x 1080 )"
16:09:48.819 Info: Elements collection reload
16:09:49.047 Info: Elements collection finished to be loaded in 228 ms 16:09:48.819 Info: Elements collection reload
Le Laptop sur WIN 10
SSD NVME PCIE 3X
17:19:56.154 Info: Start-up
17:19:56.157 Debug: "File C:/Users/hp/Application Data/qet/20220125.log is deleted!" (../sources/main.cpp:150, void delete_old_log_files(int))
17:19:56.540 Info: debugging enabled: false
17:19:56.541 Info: Qt library version: 5.15.2
17:19:56.541 Info: Qt library location default prefix: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
17:19:56.542 Info: Qt library location documentation: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/doc"
17:19:56.543 Info: Qt library location headers: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/include"
17:19:56.544 Info: Qt library location libraries: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/lib"
17:19:56.545 Info: Qt library location executables: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
17:19:56.546 Info: Qt library location Qt binaries: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
17:19:56.547 Info: Qt library location Qt plugins: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/plugins"
17:19:56.547 Info: Qt library location installed QML extensions: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/imports"
17:19:56.548 Info: Qt library location installed QML extensions: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/qml"
17:19:56.549 Info: Qt library location dependent Qt data: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
17:19:56.550 Info: Qt library location independent Qt data: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
17:19:56.551 Info: Qt library location translation: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/translations"
17:19:56.551 Info: Qt library location examples: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/examples"
17:19:56.552 Info: Qt library location Qt testcases: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/tests"
17:19:56.553 Info: "QElectroTech V 0.90-DEV+35cd790c8b0a58100c957a06d79751d3"
17:19:56.554 Info: "Compilation : GCC 9.3.0"
17:19:56.554 Info: "Built with Qt 5.15.2 - Date : Feb 6 2022 : 16:58:50"
17:19:56.555 Info: "Run with Qt 5.15.2 using 8 thread(s)"
17:19:56.556 Info: "CPU : NAME \r\r\nINTEL(R) CORE(TM) I7-8550U CPU @ 1.80GHZ \r\r\n\r\r\n"
17:19:56.557 Info: "RAM Total : 16199 MB"
17:19:56.558 Info: "RAM Available : 11695 MB"
17:19:56.559 Info: "GPU : VideoProcessor \r\r\nIntel(R) UHD Graphics Family \r\r\n\r\r\n"
17:19:56.560 Info: "GPU RAM : RAM Total : AdapterRAM \r\r\n1073741824 \r\r\n\r\r\n B"
17:19:56.560 Info: "OS : winnt - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19044"
17:19:56.561 Info: *** Qt screens ***
17:19:56.562 Info: "( 1 : 3840 x 2160 )"
17:19:56.604 Info: Elements collection reload
17:19:58.186 Info: Elements collection finished to be loaded in 1581 ms 17:19:56.604 Info: Elements collection reload
Un test avec VM KVM Flatpak vCPU allocation 24
SSD SATA 3
18:30:04.986 Info: Start-up
18:30:04.986 Debug: "File /home/laurent/.qet/20220115.log is deleted!" (sources/main.cpp:150, void delete_old_log_files(int))
18:30:05.040 Info: debugging enabled: false
18:30:05.041 Info: Qt library version: 5.15.3
18:30:05.041 Info: Qt library location default prefix: "/usr"
18:30:05.041 Info: Qt library location documentation: "/usr/doc"
18:30:05.041 Info: Qt library location headers: "/usr/include"
18:30:05.041 Info: Qt library location libraries: "/usr/lib/x86_64-linux-gnu"
18:30:05.041 Info: Qt library location executables: "/usr/lib/libexec"
18:30:05.041 Info: Qt library location Qt binaries: "/usr/bin"
18:30:05.041 Info: Qt library location Qt plugins: "/usr/lib/plugins"
18:30:05.041 Info: Qt library location installed QML extensions: "/usr/lib/imports"
18:30:05.041 Info: Qt library location installed QML extensions: "/usr/lib/qml"
18:30:05.041 Info: Qt library location dependent Qt data: "/usr/lib"
18:30:05.041 Info: Qt library location independent Qt data: "/usr"
18:30:05.042 Info: Qt library location translation: "/usr/translations"
18:30:05.042 Info: Qt library location examples: "/usr/examples"
18:30:05.042 Info: Qt library location Qt testcases: "/usr/tests"
18:30:05.042 Info: Qt library location Qt settings: "/usr/etc/xdg"
18:30:05.042 Info: "GitRevision 04d478882eb32077fd7df6ba267f214f1340b7a0"
18:30:05.042 Info: "QElectroTech V 0.90-DEV+04d478882"
18:30:05.042 Info: "Compilation: GCC 10.2.0"
18:30:05.042 Info: "Built with Qt 5.15.3 - Date : Jan 15 2022 : 09:11:13"
18:30:05.042 Info: "Run with Qt 5.15.3 using 48 thread(s)"
18:30:05.042 Info: "CPU : model name\t: AMD Ryzen Threadripper 3960X 24-Core Processor\n"
18:30:05.042 Info: "RAM Total : 15640 MB"
18:30:05.042 Info: "RAM Available : 14273 MB"
18:30:05.042 Info: "GPU : Red Hat, Inc. Virtio GPU (rev 01)\n"
18:30:05.042 Info: "GPU RAM : @ToDo"
18:30:05.042 Info: "OS : linux - x86_64 - Version : KDE Flatpak runtime - Kernel : 5.10.0-11-amd64"
18:30:05.042 Info: *** Qt screens ***
18:30:05.042 Info: "( 1 : 1920 x 1200 )"
18:30:05.256 Info: Elements collection reload
18:30:05.776 Info: Elements collection finished to be loaded in 519 ms 18:30:05.256 Info: Elements collection reload
Avec VM KVM AppImage vCPU allocation 24
SSD SATA 3
18:22:57.470 Info: Start-up
18:22:57.471 Debug: "File /home/laurent/.qet/20210222.log is deleted!" (../sources/main.cpp:150, void delete_old_log_files(int))
18:22:57.471 Debug: "File /home/laurent/.qet/20210225.log is deleted!" (../sources/main.cpp:150, void delete_old_log_files(int))
18:22:57.505 Info: debugging enabled: false
18:22:57.506 Info: Qt library version: 5.15.2
18:22:57.506 Info: Qt library location default prefix: "/tmp/.mount_QElectU9FiXb/usr"
18:22:57.506 Info: Qt library location documentation: "/tmp/.mount_QElectU9FiXb/usr/doc"
18:22:57.506 Info: Qt library location headers: "/tmp/.mount_QElectU9FiXb/usr/include"
18:22:57.506 Info: Qt library location libraries: "/tmp/.mount_QElectU9FiXb/usr/lib"
18:22:57.506 Info: Qt library location executables: "/tmp/.mount_QElectU9FiXb/usr/libexec"
18:22:57.506 Info: Qt library location Qt binaries: "/tmp/.mount_QElectU9FiXb/usr/bin"
18:22:57.506 Info: Qt library location Qt plugins: "/tmp/.mount_QElectU9FiXb/usr/plugins"
18:22:57.506 Info: Qt library location installed QML extensions: "/tmp/.mount_QElectU9FiXb/usr/qml"
18:22:57.506 Info: Qt library location dependent Qt data: "/tmp/.mount_QElectU9FiXb/usr"
18:22:57.506 Info: Qt library location independent Qt data: "/tmp/.mount_QElectU9FiXb/usr"
18:22:57.506 Info: Qt library location translation: "/tmp/.mount_QElectU9FiXb/usr/translations"
18:22:57.506 Info: Qt library location examples: "/tmp/.mount_QElectU9FiXb/usr/examples"
18:22:57.506 Info: Qt library location Qt testcases: "/tmp/.mount_QElectU9FiXb/usr/tests"
18:22:57.506 Info: Qt library location Qt settings: "/tmp/.mount_QElectU9FiXb/usr"
18:22:57.506 Info: "GitRevision 04d478882eb32077fd7df6ba267f214f1340b7a0"
18:22:57.506 Info: "QElectroTech V 0.90-DEV+04d478882"
18:22:57.506 Info: "Compilation : GCC 8.3.0"
18:22:57.506 Info: "Built with Qt 5.15.2 - Date : Feb 6 2022 : 18:18:27"
18:22:57.506 Info: "Run with Qt 5.15.2 using 24 thread(s)"
18:22:57.506 Info: "CPU : model name\t: AMD Ryzen Threadripper 3960X 24-Core Processor\n"
18:22:57.506 Info: "RAM Total : 15682 MB"
18:22:57.506 Info: "RAM Available : 14374 MB"
18:22:57.506 Info: "GPU : Red Hat, Inc Virtio GPU (rev 01)\n"
18:22:57.506 Info: "GPU RAM : @ToDo"
18:22:57.506 Info: "OS : linux - x86_64 - Version : Debian GNU/Linux 10 (buster) - Kernel : 4.19.0-18-amd64"
18:22:57.506 Info: *** Qt screens ***
18:22:57.506 Info: "( 1 : 1920 x 1080 )"
18:22:57.743 Info: Elements collection reload
18:22:58.298 Info: Elements collection finished to be loaded in 554 ms 18:22:57.743 Info: Elements collection reload
Et pour finir la VM KVM macOS 10.15
SSD SATA 3
18:13:57.593 Info: Start-up
18:13:57.594 Debug: "File /Users/laurent/.qet/20220106.log is deleted!" (sources/main.cpp:150, void delete_old_log_files(int))
18:13:57.612 Info: debugging enabled: false
18:13:57.613 Info: Qt library version: 5.15.2
18:13:57.613 Info: Qt library location default prefix: "/Applications/qelectrotech.app/Contents"
18:13:57.613 Info: Qt library location documentation: "/Applications/qelectrotech.app/Contents/doc"
18:13:57.614 Info: Qt library location headers: "/Applications/qelectrotech.app/Contents/include"
18:13:57.614 Info: Qt library location libraries: "/Applications/qelectrotech.app/Contents/lib"
18:13:57.614 Info: Qt library location executables: "/Applications/qelectrotech.app/Contents/libexec"
18:13:57.614 Info: Qt library location Qt binaries: "/Applications/qelectrotech.app/Contents/bin"
18:13:57.614 Info: Qt library location Qt plugins: "/Applications/qelectrotech.app/Contents/PlugIns"
18:13:57.615 Info: Qt library location installed QML extensions: "/Applications/qelectrotech.app/Contents/Resources/qml"
18:13:57.615 Info: Qt library location dependent Qt data: "/Applications/qelectrotech.app/Contents"
18:13:57.617 Info: Qt library location independent Qt data: "/Applications/qelectrotech.app/Contents"
18:13:57.617 Info: Qt library location translation: "/Applications/qelectrotech.app/Contents/translations"
18:13:57.617 Info: Qt library location examples: "/Applications/qelectrotech.app/Contents/examples"
18:13:57.617 Info: Qt library location Qt testcases: "/Applications/qelectrotech.app/Contents/tests"
18:13:57.617 Info: Qt library location Qt settings: "/Applications/qelectrotech.app/Contents"
18:13:57.618 Info: "GitRevision 579101d19b7a015190c09e1cd35575f52617ffa1"
18:13:57.618 Info: "QElectroTech V 0.90-DEV"
18:13:57.618 Info: "Compilation: CLANG 11.0.3 (clang-1103.0.32.29)"
18:13:57.618 Info: "Built with Qt 5.15.2 - Date : Feb 6 2022 : 18:10:03"
18:13:57.618 Info: "Run with Qt 5.15.2 using 48 thread(s)"
18:13:57.618 Info: "CPU : Intel Core 2 Duo P9xxx (Penryn Class Core 2)\n"
18:13:57.619 Info: "RAM Total : 32768 MB"
18:13:57.619 Info: ""
18:13:57.619 Info: "GPU : "
18:13:57.619 Info: "GPU RAM : "
18:13:57.620 Info: "OS : darwin - x86_64 - Version : macOS 10.15 - Kernel : 19.6.0"
18:13:57.620 Info: *** Qt screens ***
18:13:57.620 Info: "( 1 : 1920 x 1080 )"
18:13:57.785 Info: Elements collection reload
18:14:01.819 Info: Elements collection finished to be loaded in 4034 ms 18:13:57.785 Info: Elements collection reload
commit 855162bb03638e982bc6868448aa6623e3cbe3fa
Author: Laurent Trinques <scorpio@>
Date: Wed Feb 16 12:34:04 2022 +0100
Improve QElapsedTimer to calculate the time used to reload the item collection in seconds instead of ms
12:46:40.276 Info: Start-up
12:46:40.333 Info: debugging enabled: false
12:46:40.334 Info: Qt library version: 5.15.2
12:46:40.334 Info: Qt library location default prefix: "/usr"
12:46:40.334 Info: Qt library location documentation: "/usr/share/qt5/doc"
12:46:40.334 Info: Qt library location headers: "/usr/include/x86_64-linux-gnu/qt5"
12:46:40.334 Info: Qt library location libraries: "/usr/lib/x86_64-linux-gnu"
12:46:40.334 Info: Qt library location executables: "/usr/lib/x86_64-linux-gnu/qt5/libexec"
12:46:40.334 Info: Qt library location Qt binaries: "/usr/lib/qt5/bin"
12:46:40.334 Info: Qt library location Qt plugins: "/usr/lib/x86_64-linux-gnu/qt5/plugins"
12:46:40.334 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/imports"
12:46:40.334 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/qml"
12:46:40.334 Info: Qt library location dependent Qt data: "/usr/lib/x86_64-linux-gnu/qt5"
12:46:40.334 Info: Qt library location independent Qt data: "/usr/share/qt5"
12:46:40.334 Info: Qt library location translation: "/usr/share/qt5/translations"
12:46:40.334 Info: Qt library location examples: "/usr/lib/x86_64-linux-gnu/qt5/examples"
12:46:40.334 Info: Qt library location Qt testcases: "/usr/tests"
12:46:40.334 Info: Qt library location Qt settings: "/etc/xdg"
12:46:40.334 Info: "QElectroTech V 0.90-DEV+855162bb0b0a58100c957a06d79751d3"
12:46:40.334 Info: "Compilation: GCC 11.2.0"
12:46:40.334 Info: "Built with Qt 5.15.2 - Date : Feb 16 2022 : 11:37:57"
12:46:40.334 Info: "Run with Qt 5.15.2 using 48 thread(s)"
12:46:40.334 Info: "CPU : model name\t: AMD Ryzen Threadripper 3960X 24-Core Processor\n"
12:46:40.334 Info: "RAM Total : 64257 MB"
12:46:40.334 Info: "RAM Available : 56468 MB"
12:46:40.334 Info: "GPU : Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7)\n"
12:46:40.334 Info: "GPU RAM : @ToDo"
12:46:40.334 Info: "OS : linux - x86_64 - Version : Debian GNU/Linux bookworm/sid - Kernel : 5.16.8-vanilla"
12:46:40.334 Info: *** Qt screens ***
12:46:40.334 Info: "( 1 : 3840 x 2160 )"
12:46:40.334 Info: "( 2 : 1920 x 1080 )"
12:46:40.577 Info: Elements collection reload
12:46:40.824 Info: Elements collection finished to be loaded in 0.247 seconds 12:46:40.577 Info: Elements collection reload
commit 830a70ac94bc62cdeb9c91129dd0260528085c54
Date: Thu Feb 17 19:01:56 2022 +0100
Add Linux pc.gpu.RAM informations,
but need mesa-utils dependency on Linux OS
04:25:58.467 Info: Start-up
04:25:58.647 Info: debugging enabled: false
04:25:58.647 Info: Qt library version: 5.15.2
04:25:58.647 Info: Qt library location default prefix: "/usr"
04:25:58.647 Info: Qt library location documentation: "/usr/share/qt5/doc"
04:25:58.647 Info: Qt library location headers: "/usr/include/x86_64-linux-gnu/qt5"
04:25:58.647 Info: Qt library location libraries: "/usr/lib/x86_64-linux-gnu"
04:25:58.647 Info: Qt library location executables: "/usr/lib/x86_64-linux-gnu/qt5/libexec"
04:25:58.647 Info: Qt library location Qt binaries: "/usr/lib/qt5/bin"
04:25:58.647 Info: Qt library location Qt plugins: "/usr/lib/x86_64-linux-gnu/qt5/plugins"
04:25:58.647 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/imports"
04:25:58.647 Info: Qt library location installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt5/qml"
04:25:58.648 Info: Qt library location dependent Qt data: "/usr/lib/x86_64-linux-gnu/qt5"
04:25:58.648 Info: Qt library location independent Qt data: "/usr/share/qt5"
04:25:58.648 Info: Qt library location translation: "/usr/share/qt5/translations"
04:25:58.648 Info: Qt library location examples: "/usr/lib/x86_64-linux-gnu/qt5/examples"
04:25:58.648 Info: Qt library location Qt testcases: "/usr/tests"
04:25:58.648 Info: Qt library location Qt settings: "/etc/xdg"
04:25:58.648 Info: "QElectroTech V 0.90-DEV+830a70ac9b0a58100c957a06d79751d3"
04:25:58.648 Info: "Compilation: GCC 11.2.0"
04:25:58.648 Info: "Built with Qt 5.15.2 - Date : Feb 17 2022 : 18:13:44"
04:25:58.648 Info: "Run with Qt 5.15.2 using 48 thread(s)"
04:25:58.648 Info: "CPU : model name\t: AMD Ryzen Threadripper 3960X 24-Core Processor\n"
04:25:58.648 Info: "RAM Total : 64257 MB"
04:25:58.648 Info: "RAM Available : 59535 MB"
04:25:58.648 Info: "GPU : Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7)\n"
04:25:58.648 Info: "GPU RAM : Video memory: 4096MB\n Dedicated video memory: 4096 MB\n Currently available dedicated video memory: 2618 MB\n"
04:25:58.648 Info: "OS : linux - x86_64 - Version : Debian GNU/Linux bookworm/sid - Kernel : 5.16.10-vanilla"
04:25:58.648 Info: *** Qt screens ***
04:25:58.648 Info: "( 1 : 3840 x 2160 )"
04:25:58.648 Info: "( 2 : 1920 x 1080 )"
04:25:58.789 Info: Elements collection reload
04:25:59.036 Info: Elements collection finished to be loaded in 0.246 seconds
Checked on little CPU Intel Celeron G3900T HP ProDesk 400 G3
https://support.hp.com/ca-fr/product/hp … /c05366495
18:39:39.119 Info: Start-up
18:39:39.686 Info: Elements collection reload
18:39:48.173 Info: debugging enabled: false
18:39:48.174 Info: Qt library version: 5.15.2
18:39:48.174 Info: Qt library location default prefix: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
18:39:48.175 Info: Qt library location documentation: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/doc"
18:39:48.176 Info: Qt library location headers: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/include"
18:39:48.176 Info: Qt library location libraries: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/lib"
18:39:48.177 Info: Qt library location executables: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
18:39:48.178 Info: Qt library location Qt binaries: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin"
18:39:48.179 Info: Qt library location Qt plugins: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/plugins"
18:39:48.179 Info: Qt library location installed QML extensions: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/imports"
18:39:48.180 Info: Qt library location installed QML extensions: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/qml"
18:39:48.180 Info: Qt library location dependent Qt data: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
18:39:48.181 Info: Qt library location independent Qt data: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5"
18:39:48.181 Info: Qt library location translation: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/translations"
18:39:48.182 Info: Qt library location examples: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/examples"
18:39:48.182 Info: Qt library location Qt testcases: "/home/laurent/digikam3/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/tests"
18:39:48.183 Info: "QElectroTech V 0.90-DEV+bb1a0767ab0a58100c957a06d79751d3"
18:39:48.183 Info: "Compilation : GCC 9.3.0"
18:39:48.184 Info: "Built with Qt 5.15.2 - Date : Feb 24 2022 : 18:23:42"
18:39:48.184 Info: "Run with Qt 5.15.2 using 2 thread(s)"
18:39:48.185 Info: "CPU : NAME \r\r\nINTEL(R) CELERON(R) CPU G3900T @ 2.60GHZ \r\r\n\r\r\n"
18:39:48.185 Info: "RAM Total : 3991 MB"
18:39:48.186 Info: "RAM Available : 1875 MB"
18:39:48.186 Info: "GPU : VideoProcessor \r\r\nIntel(R) HD Graphics Family \r\r\n\r\r\n"
18:39:48.187 Info: "GPU RAM : RAM Total : AdapterRAM \r\r\n1073741824 \r\r\n\r\r\n B"
18:39:48.187 Info: "OS : winnt - x86_64 - Version : Windows 10 Version 1709 - Kernel : 10.0.16299"
18:39:48.188 Info: *** Qt screens ***
18:39:48.188 Info: "( 1 : 1440 x 900 )"
18:40:18.280 Info: Elements collection finished to be loaded in 38.593 seconds
Commercial-Only Qt 5.15.3 LTS Now Released As Open-Source
https://www.phoronix.com/scan.php?page= … pen-Source
https://lists.qt-project.org/pipermail/ … 42262.html
FYI, I updated MXE cross environment and libraries for Windows packages to :
GCC 9 -> GCC 10.3 removed!
Qt 5.15.2 -> Qt 5.15.3
KF5 5.77 -> KF5 5.90
FYI, I updated macOS bundle packages to :
KF5 5.77 -> KF5 5.92
Vbxier has reworked pneumatic symbols, I moved old symbol to https://github.com/qelectrotech/qelectr … nt-contrib
Thanks again Vbxier for your contribution.
Good evening! :p
For me is time to sleep.
Add disks volumes mounted informations :
16:04:54.563 Info: "QElectroTech V 0.90-DEV"
16:04:54.563 Info: "Compilation : GCC 11.2.0"
16:04:54.563 Info: "Built with Qt 5.15.2 - Date : Apr 7 2022 : 16:04:50"
16:04:54.563 Info: "Run with Qt 5.15.2 using 48 thread(s)"
16:04:54.563 Info: "CPU : model name\t: AMD Ryzen Threadripper 3960X 24-Core Processor\n"
16:04:54.563 Info: "RAM Total : 64257 MB"
16:04:54.563 Info: "RAM Available : 57973 MB"
16:04:54.563 Info: "GPU : Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] (rev c7)\n"
16:04:54.563 Info: "GPU RAM : Video memory: 4096MB\n Dedicated video memory: 4096 MB\n Currently available dedicated video memory: 2289 MB\n"
16:04:54.563 Info: "OS : linux - x86_64 - Version : Debian GNU/Linux bookworm/sid - Kernel : 5.17.1-vanilla"
16:04:54.563 Info: *** Qt screens ***
16:04:54.563 Info: "( 1 : 3840 x 2160 )"
16:04:54.563 Info: "( 2 : 1920 x 1080 )"
16:04:54.564 Info: DISK : /run
16:04:54.564 Info: fileSystemType: "tmpfs"
16:04:54.565 Info: sizeTotal: 6 GB
16:04:54.565 Info: availableSize: 6 GB
16:04:54.565 Info: DISK : /
16:04:54.565 Info: fileSystemType: "ext4"
16:04:54.565 Info: sizeTotal: 27 GB
16:04:54.565 Info: availableSize: 24 GB
16:04:54.565 Info: DISK : /run/lock
16:04:54.565 Info: fileSystemType: "tmpfs"
16:04:54.565 Info: sizeTotal: 0 GB
16:04:54.565 Info: availableSize: 0 GB
16:04:54.565 Info: DISK : /home
16:04:54.565 Info: sizeTotal: 253 GB
16:04:54.565 Info: availableSize: 234 GB
16:04:54.565 Info: DISK : /boot/efi
16:04:54.565 Info: fileSystemType: "vfat"
16:04:54.565 Info: DISK : /media/backup2
16:04:54.565 Info: sizeTotal: 322 GB
16:04:54.565 Info: availableSize: 276 GB
16:04:54.565 Info: DISK : /media/backup6
16:04:54.565 Info: sizeTotal: 1353 GB
16:04:54.565 Info: availableSize: 1260 GB
16:04:54.565 Info: DISK : /run/user/1000
16:04:54.565 Info: DISK : /run/user/1000/doc
16:04:54.565 Info: fileSystemType: "fuse.portal"
16:04:54.566 Info: DISK USED: /media/backup6
16:04:54.566 Info: fileSystemType: "ext4"
16:04:54.566 Info: sizeTotal: 1353 GB
16:04:54.566 Info: availableSize: 1260 GB
16:04:54.721 Info: Elements collection reload
16:04:54.805 Info: Elements collection finished to be loaded in 0.084 seconds
For macOS bundle I try Monterey, yes I know new OSX SDK is for Qt 6.2.3 ...
I can't saw any problems, please send back your feedbacks..
I'm thinking of buying a certificate to sign Windows and maybe for macOS packages.?... and using osslsigncode to sign Windows packages, what do you think?
It would cost about ~ 130€ with shipping for the first year for certicate and an USB key encrypted, then 25€/year to renew the certificate.
We can afford to pay for it now thanks to your Paypal donations, but before I go ahead I'd like your opinion, for those who have tested it?
As you know, under Windows and macOS the installation of QET is painful with workarounds for mac and warning messages from Windows during installation.
https://shop.certum.eu/open-source-code-signing.html
https://github.com/mtrojnar/osslsigncode
https://www.msz.it/a-cheap-code-signing … lkthrough/
EDIT:
Open Source Code Signing Certificate
We issue Open Source Code Signing certificates only to natural persons.
We would like to inform you that since March 13, 2017, the option of telephone verification for Open Source Code Signing certificates is not available.
Verification based on documentsCopies of the following documents must be provided to Certum for verification purposes:
confirmation of identity at the Registration Point or at the Identity Confirmation Point (details: https://certum.store/certum-reseller-points-map, sample statement can be downloaded here (link: https://files.certum.eu/documents/repsi … ntity.pdf) or
notarized proof of identity or for quicker issuance
a copy of the identity document of the person requesting the certificate (identity card, passport, driver’s license, permanent residence card).
ATTENTION! The copy should be a complete reproduction of the document (i.e. include all of its pages).The identity can also be confirmed on the basis of a valid qualified certificate issued for the Subscriber by Certum.
anda utilities (gas, electricity, water, telephone, etc.) bill issued to the subscriber,
the website address of the ongoing Open Source project.
The project must be publicly available and indicate clearly the subscriber’s relationship with the project. If Certum is unable to identify the project based on publicly available information, the certification application will be rejected.
All collected documents should be sent to Certum using one of the following methods:by e-mail as a password-protected file to the address: ccp@certum.pl (recommended form),
please contact the Certum technical support helpline in order to determine how to transfer the password
by fax to: +48 91 4257 422
by post to:
Asseco Data Systems S.A.
ul. Bajeczna 13
71-838 Szczecin
NOTE
1. Open Source Code Signing certificates cannot contain domain names and IP addresses.
2. The person requesting the certificate must also be the certificate subscriber.
3. We issue Open Source Code Signing certificates only to natural persons.
4. When a certificate is issued, the phrase “Open Source Developer” is automatically added in the “CN” (Common Name) field, while the Organization field only contains “Open Source Developer”.NOTE!
Validity of the documents being the basis for verification of certification applications:For new certificate requests and for renewed certificates, documents and information from public registers cannot be older than 13 months,
Authorization documents, whether they are timely or not – remain valid for 13 months from the date of issue,
Identity documents must be up-to-date (valid) on the day the certificate is issued.
Identity documents delivered to Certum should be e-mailed in the form of a password-protected file, please contact the Certum technical support helpline in order to determine how to transfer the password
Well, WTF ...... !
Bonjour, me voici de retour après une longue période d’absence (qui risque de continuer encore un peu).
J’ai terminé l’une des taches liée au générateur de bornier et mergé la branche terminal-strip dans la branche master, ce qui pour être plus claire vous permet de profiter de tous cela dans la version de développement de Qet.
Je vous encourage à tester (Sur des projets ne craignant pas d’être cassé), et me faire part de vos remarques (bug, ce qui va, ce qui ne va pas, amélioration possible, etc.).
Petit topo sur la situation :
Actuellement il est uniquement possible de gérer tout ce qui caractérise un bornier.
-Créer / supprimer un bornier.
-Paramétrer un bornier.
-Ajouter / supprimer des bornes à un bornier.
-Créer des bornes à étages.
-Ponter des bornes.
Toutes cela s’effectue dans une fenêtre dédiée aux borniers (cette fenêtre est non modale, ce qui signifie que vous pouvez la garder ouverte à côté de la fenêtre principale tout en utilisant cette dernière).
Ce qu’il reste à faire :
-Ajouter un plan de bornier sur un folio.
-Ajouter de l’automatisation dans la création de bornier (demandera quelques travaux annexe au bornier comme par exemple une vraie notion de potentiel électrique)
-Éditeur de propriété des bornes directement depuis la fenêtre du gestionnaire de bornier.
Bien que le but final d’un gestionnaire de bornier soit l’affichage de ceux-ci sur les folios, la partie la plus importante (et de loin) est celle que je viens de décrire. Le plan de borne sur le folio n’est lui qu’un « simple » dessin, c’est pourquoi vos retours seront très importants.
Le filtre pour la position n 'est pas bonne en fonction du Label, il manque aussi de récupérer le numéro de fil lié à la borne..automatiquement.
https://download.qelectrotech.org/qet/f … er_dev.png
Le double click dans le champ de la xref d'une borne est une bonne idée, car il vient pointer la vue sur le schéma précisément sur cette borne.
Le calcul est très long même sur une grosse machine, une progressBar indiquerait l'avancement du calcul pour l'utilisateur.
Bonjour j'ai un soucis avec le QET depuis que j'ai le windows 11 sur mon PC. Le QET se lance mais j'ai aucuns élements.
j'ai téléchargé la dernière version 0.90 dev mais le problème est toujours présent
QElectroTech → News → Nouveautés de la version de développement 0.9> 0.200.1
Generated in 0.052 seconds (65% PHP - 35% DB) with 11 queries
