Topic: Exporting issues - csv and internal database
Hello
I am running the 0.9-dev version on my arch based linux machine. I used flatpak to install.
The export to csv function does not have all elements in the csv document.
I also do not have the export internal database function available. I have sqlite installed.
Any advice will be appreciated
Below my setup for reference
QElectroTech V 0.90-DEV+855162bb0
Compilation : GCC 10.2.0
Built with Qt 5.15.3 - Date : Jan 15 2022 : 09:11:13
Run with Qt 5.15.3 using 4 thread(s)
CPU : model name : Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz
RAM Total : 7828 MB
RAM Available : 4009 MB
GPU : Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09) NVIDIA Corporation GF119M [NVS 4200M] (rev a1)
GPU RAM : @ToDo
OS : linux - x86_64 - Version : KDE Flatpak runtime - Kernel : 5.16.10-arch1-1
*** Qt screens ***
( 1 : 1920 x 1080 )
Re: Exporting issues - csv and internal database
humm ....  If I remember Sqlite3 code in sources to export QET project database to SQL was disabled on my packages : AppImage, Flatpak, and macOS.
sed -i 's/DEFINES += QET_EXPORT_PROJECT_DB/#DEFINES += QET_EXPORT_PROJECT_DB/' qelectrotech.pro
Because either it works badly, or very complicated to integrate sqlite3 dependency in macOS bundles ...
Maybe you could compile QET yourself or check Arch package?
I removed sed command line and send new Flapak build, please try it.
Hi Scorpio
I will try tonight.
I created a python script to generate a basic parts list in csv format.
FYI, I also removed sed command line and send new AppImage build.
https://git.tuxfamily.org/qet/qet.git/c … 65320400a0
@Xenotek: I tried Flatpak and AppImage database export and export to csv function works now.
Icon: qelectrotech
Exec: qelectrotech %F
Comment: Edit electrical diagrams.
Type: Application
Categories: Graphics;Qt;VectorGraphics;Science;Electricity;Engineering;
/home/laurent/qet_git/appdir/qelectrotech/usr/bin/qelectrotech used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libpcre2-16.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libavahi-common.so.3 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libicui18n.so.63 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libXi.so.6 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-glx.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libfam.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libgraphite2.so.3 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5Xml.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libwebp.so.6 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libgssapi_krb5.so.2 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5Gui.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libjbig.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libicudata.so.63 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-shape.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-xfixes.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5CoreAddons.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-util.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5X11Extras.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libbz2.so.1.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5Archive.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libmng.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libpng16.so.16 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-xinerama.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libzstd.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libhogweed.so.4 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-sync.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libXau.so.6 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libnettle.so.6 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5Codecs.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libGLX.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libcups.so.2 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5Core.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5IconThemes.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libtasn1.so.6 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libIlmThread-2_2.so.23 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libkrb5support.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libdouble-conversion.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libgnutls.so.30 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5ConfigGui.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5ItemViews.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libmariadb.so.3 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libImath-2_2.so.23 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5ConfigCore.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5I18n.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5Widgets.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-xkb.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5WidgetsAddons.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libk5crypto.so.3 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-render.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libffi.so.6 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libXdmcp.so.6 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libtiff.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libkrb5.so.3 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libicuuc.so.63 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-shm.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-keysyms.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libIex-2_2.so.23 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5GuiAddons.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxkbcommon.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libXrender.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/liblz4.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libX11-xcb.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-image.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5XcbQpa.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libjpeg.so.62 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libHalf.so.23 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5Auth.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libIlmImf-2_2.so.23 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5PrintSupport.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5Network.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libsqlite3.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5Svg.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libgmp.so.10 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libpcre.so.3 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libXext.so.6 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libgcrypt.so.20 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libsystemd.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libunistring.so.2 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-randr.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libbsd.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5Concurrent.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-icccm.so.4 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libEGL.so.1 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libavahi-client.so.3 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libKF5ConfigWidgets.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxkbcommon-x11.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/liblcms2.so.2 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libGLdispatch.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5DBus.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libwebpdemux.so.2 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libidn2.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/liblzma.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libQt5Sql.so.5 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libxcb-render-util.so.0 used for determining architecture x86_64
/home/laurent/qet_git/appdir/qelectrotech/usr/lib/libdbus-1.so.3 used for determining architecture x86_64
Using architecture x86_64
App name for filename: QElectroTech_0.9-DEV-r7545
/home/laurent/qet_git/appdir/qelectrotech should be packaged as QElectroTech_0.9-DEV-r7545-x86_64.AppImage
Generating squashfs...
Size of the embedded runtime: 157624 bytes
mksquashfs commandline: /tmp/.mount_linuxdV4Lch0/usr/bin/../lib/appimagekit/mksquashfs /home/laurent/qet_git/appdir/qelectrotech QElectroTech_0.9-DEV-r7545-x86_64.AppImage -offset 157624 -comp gzip -root-owned -noappend -mkfs-fixed-time 0
Parallel mksquashfs: Using 24 processors
Creating 4.0 filesystem on QElectroTech_0.9-DEV-r7545-x86_64.AppImage, block size 131072.
[=========================================================================================================================================================================================================================================================-] 11091/11091 100%
Exportable Squashfs 4.0 filesystem, gzip compressed, data block size 131072
        compressed data, compressed metadata, compressed fragments, compressed xattrs
        duplicates are removed
Filesystem size 51976.09 Kbytes (50.76 Mbytes)
        24.44% of uncompressed filesystem size (212681.71 Kbytes)
Inode table size 104186 bytes (101.74 Kbytes)
        28.38% of uncompressed inode table size (367046 bytes)
Directory table size 109077 bytes (106.52 Kbytes)
        33.16% of uncompressed directory table size (328912 bytes)
Number of duplicate files found 209
Number of inodes 11316
Number of files 10091
Number of fragments 631
Number of symbolic links  1
Number of device nodes 0
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 1224
Number of ids (unique uids + gids) 1
Number of uids 1
        root (0)
Number of gids 1
        root (0)
Embedding ELF...
Marking the AppImage as executable...
Embedding MD5 digest
Success
Please consider submitting your AppImage to AppImageHub, the crowd-sourced
central directory of available AppImages, by opening a pull request
at https://github.com/AppImage/appimage.github.io
+ rm qelectrotech/AppRun
+ sed -i 's/QElectroTech_0.9-DEV.*/QElectroTech_0.9-DEV-r7547/' qelectrotech/qelectrotech.desktop
+ cp AppRun qelectrotech/
+ rm QElectroTech_0.9-DEV-r7545-x86_64.AppImage
+ ARCH=x86_64
+ ./appimagetool-x86_64.AppImage qelectrotech
appimagetool, continuous build (commit 758f8e7), build 1771 built on 2018-07-10 10:44:25 UTC
/home/laurent/qet_git/appdir/qelectrotech/qelectrotech.desktop: warning: key "Keywords" in group "Desktop Entry" is a reserved key for KDE
/home/laurent/qet_git/appdir/qelectrotech should be packaged as QElectroTech_0.9-DEV-r7547-x86_64.AppImage
WARNING: AppStream upstream metadata is missing, please consider creating it
         in usr/share/metainfo/qelectrotech.appdata.xml
         Please see https://www.freedesktop.org/software/appstream/docs/chap-Quickstart.html#sect-Quickstart-DesktopApps
         for more information or use the generator at http://output.jsbin.com/qoqukof.
Creating 4.0 filesystem on QElectroTech_0.9-DEV-r7547-x86_64.AppImage, block size 131072.
[=========================================================================================================================================================================================================================================================-] 11092/11092 100%
Filesystem size 51976.37 Kbytes (50.76 Mbytes)
        24.44% of uncompressed filesystem size (212681.87 Kbytes)
Inode table size 104211 bytes (101.77 Kbytes)
        28.39% of uncompressed inode table size (367034 bytes)
Directory table size 109191 bytes (106.63 Kbytes)
        33.20% of uncompressed directory table size (328900 bytes)
Number of files 10092
Number of symbolic links  0
Number of uids 1
        root (0)
Number of gids 1
        root (0)
Embedding ELF...
Success
+ chmod -x QElectroTech_0.9-DEV-r7547-x86_64.AppImage
