Topic: Noobie: Creating connectable elements with images
Hi Folks,
Noobie to forum...  working on a solar wiring layouts and would like to use pictures of the actual components within the wiring diagram.  Is there anyway to create connectable elements with jpeg images embeded ? .
Thanx
Example attached.
Re: Noobie: Creating connectable elements with images
you have two solution:
Convert your image to DXF by online converter, use DXFtoelmt converter program to create QET element.
Edit this new element, add terminal, text etc.
Or create a element with only a terminal in element editor, put this terminal above your picture in diagram to create connectable elements with images.
