Topic: Import DXF into QElectrotech problems
Hi Guys,
I have downloaded the DXF to QET.exe file and used it as you showed another user, however, this program stops "not responding" through running. i have got through once and there is no transfer file in my designated folder for element. please can you help?
Re: Import DXF into QElectrotech problems
try an older version, the last one seems to crash.
Thank you so much, I will try now.
Hi, still not working. went through program until the end, then told me could not save element. Was trying to save on desk top yet I gave the path as in the elements of QElectrotech
I used an older version and it went through. I then hit "create Element" and the result I got was "Lelement a bien ete enregistre", but I cannot find it anywhere?
Refresh your collection in QET program.
How do I do that? I have closed and re-opened the software
Right click on collections view.
Ok, done that, still not there?
Have you configured the path to the user collection correctly in the DXF converter?
What your QET version and OS?
I use windows 10 with QET V0.8
For installer version :
C:\Users\user_name\AppData\Roaming\qet\elements\
This is only what I have made in user collection. Still no DXF I loaded
Hi Scorpio, do you have any solution further for me?
See DXF converter logs, or run DXF converter in terminal to saw where is put the finished elmt?
Thank you
Hello.
Im new at QElectroTech.
Im using Windows 10 and i have the same problem that i cant find where is the element stored.
The version of QElectroTehc is: V0.80c+87c957a06d79751d3
Steps i have followed:
0- Create a test file in DXF format with the program FreeDraft
1- Open DXFtoQET.exe file (version 2020-05-05)
2- In the executable program:
--- 2.1 - Open dxf file
--- 2.2 - DXFDB to DB
--- 2.3 - Load dxf into proces
--- 2.4 - In the Home tab -> change directory for: Save Path element, to where i need the element to be stored
--- 2.5 - In the Settings tab -> change directory for the same as step before
--- 2.5 - Create QET elmt
--- 2.6 - Save to ELMT file
--- 2.7 - Recive a message: L'element a bien ete enregistre. and click OK.
3- Open QElectroTech and refresh collections.
I cant find the elemt file in QElectro and neither in the folder selected to be stored.
In the DXFconverter Logs i cant find the save path, it only says: Create file : /objetoprueba1qelectrodxf.elmt
but i dont know where is pointing to.
And i dont know how to run in on the terminal.
Is it necesary to have installed on the computer SQLITE program?
I hope you can help me solve this issue.
Thanks in advance and Blessings.
Path to custom collection need to be C:\Users\eangel\AppData\Roaming\qet\elements\
If you have installed QET by installer.
19 (edited by EAngel 2022-03-18 23:03:33)
Thanks for the quick reply.
I have installed QET with the exe file: Installer_QElectroTech-0.80_x86_64-win64+git7124-1.exe
C:\Users\proy\AppData\Roaming  -->> there is no qet folder
C:\Users\proy\Application Data\qet\elements -->> Heres is the customs collection created folder from QElectroTech
C:\Program Files\QElectroTech\elements -->> Here is the default version QET Collection
I have tried with the last two of them but nothing happened.
You could send your DXF?
21 (edited by EAngel 2022-03-18 22:42:27)
Yes.
It is just for testing purposes. Not very elaborated.
Voila.
23 (edited by EAngel 2022-03-18 23:12:44)
Thanks.
But the object didnt convert fully, there are missing lines :O
And i still dont know how to do it myself, is there anything else i could try?
For such a simple design, it's easier to do it yourself in the Elements editor.
Yes, but this is just for testing the converter.
I need to do more elaborated equipments.
And also i need to download ones from manufacters, so i need to convert them to .elmt files.
