Topic: Your Christmas present: QElectroTech is back
Hello,
After a long time without any news from me, here is a Christmas news to recall that the QElectroTech project is still alive. So alive the work has begun in our 0.3 branch on a regularly requested feature: the customized title blocks nomicons/smile
So, how will it work?
Customized title blocks will be rendered through templates, i.e. HTML-like descriptions of what your title block should look like.
These templates will be embedded in project files:
http://qelectrotech.org/screenshots/extras/tbt_03.png
and will be assignable to each diagram individually:
http://qelectrotech.org/screenshots/extras/tbt_04.png
They will allow you to specify both the layout and the content of the various cells. This content may include an optional label, some text containing placeholders for diagram values but also logos, both bitmap (PNG, JPEG, ...):
http://qelectrotech.org/screenshots/extras/tbt_01.png
.. and SVG:
http://qelectrotech.org/screenshots/extras/tbt_02.png
However, for the moment, the provided editor is basic, non-WYSIWYG and not intuitive at all:
http://qelectrotech.org/screenshots/extras/tbt_00.png
It is temporary of course nomicons/wink
The following page provides a commented example of title block template code: http://qelectrotech.org/wiki/titleblock_future.
That's all for today -- Merry Christmas and see you soon for other news nomicons/wink
http://scorpio810.blogdns.net/generation-debian/qelectrotech/capture%20d'%C3%A9cran7.png
Gray's Law of Programming:
Re: Your Christmas present: QElectroTech is back
Après une longue période sans news de ma part, voici une news de Noël pour rappeler que le projet QElectroTech est bien vivant. Tellement vivant que le travail a débuté dans notre branche 0.3 pour une fonctionnalité régulièrement demandée, à savoir la gestion des cartouches personnalisés nomicons/smile
Alors, comment cela va-t-il se passer ?
Les cartouches personnalisés seront rendus via des modèles, c-à-d des descriptions dans un format semblable à HTML de ce à quoi vos cartouches doivent ressembler.
Ces modèles seront embarqués dans les fichiers projets :
et pourront être utilisés pour chaque schema individuellement :
Ils vous permettront de préciser aussi bien la disposition que le contenu des différentes cellules. Ce contenu peut être un label facultatif, du texte contenant des espaces réservés pour les valeurs provenant du schéma, mais aussi des logos, aussi bien bitmap (PNG, JPEG, ...) :
.. que SVG:
Toutefois, pour le moment, l'éditeur de modèles fourni est basique, pas WYSIWYG et pas intuitif du tout :
C'est temporaire, bien entendu nomicons/wink
La page suivante fournit un exemple commenté de code pour un modèle de cartouche: http://qelectrotech.org/wiki/titleblock_future.
Voilà, c'est tout pour aujourd'hui -- Joyeux Noël et à bientôt pour d'autres news nomicons/wink
Merci beaucoup Xavier pour cette évolution ! It's really a nice present ;-)
Malgré tout comment je récupère la branche 0.3 ? car celle que j'utilise date toujours du mois de novembre il me semble. Cette évolution est elle disponible ?
Je souhaiterai la tester et l'évaluer.
Je profite également de ce courrier pour savoir s'l est prévu un système de variable à la fois pour les cartouches mais également pour tous les éléments ? En effet je pense que cela faciliterai les numérotations en automatique à la fois des éléments et des conducteurs ! Sinon je ne voi pas comment on pourrai identifier un texte d'un numéro par exemple.
Encore merci et joyeuses fêtes
Je viens de récupérer le code de la dernière version mais j'ai des erreurs de compilation ! Seulement une vingtaine de fichiers se compilent ! Avez vous une explication ?
Salut
chez moi avec Qt en version 4.6 ça compile bien , mais je ne fais pas de la compil simple :    http://qelectrotech.org/wiki/doc:packag … ing_script
apt-get install libqt4-core libqt4-dev libqt4-gui
Howto compile :
$ qmake (qmake-qt4 for Debian-based systems)
$ make
# umask 0022
# make install
Attention, c'est vraiment expérimental pour le moment, c'est loin d'être mature (je viens de commiter une correction d'ailleurs). En résumé, avec la nouvelle version, dans un projet il faut :
  * Faire un clic droit sur "Modèles de cartouches" > Importer un nouveau modèle
  * Insérer le code XML de son template, façonné comme sur http://qelectrotech.org/wiki/titleblock_future dans le champ de texte
  * Attention, subtilité temporaire : le nom du modèle (le champ de texte en haut) doit être égal à l'attribut name="..." du code XML
  * Faire "enregistrer et appliquer".
  * Le modèle doit apparaître dans le panel d'éléments, sinon c'est qu'il y a eu un problème.
  * Double-cliquer sur le cartouche d'un schéma, choisir le modèle en question, valider ; le template doit être appliqué.
  * À partir de là, "enregistrer et appliquer" met à jour le template immédiatement, on peut donc travailler dessus et tester rapidement.
  * Ne pas oublier d'enregistrer son fichier projet.
Dans un premier temps, on pourra spécifier ses propres variables (plus seulement le titre, le nom de fichier, la date et l'auteur) et leurs valeurs pour chaque schéma. Pour les éléments, c'est possible aussi dans le concept mais je ne sais pas si ce serait facilement exploitable pour le cartouche.
Pas spécialement, surtout si tu ne me fournis pas les erreurs de compilation, mais je précise de suite que pour la branche 0.3, un Qt >= 4.6.x s'impose.
bonsoir ,
les debs sont dispo sur mon dépôt ,
exemple de ce qu'on peut faire comme cartouche
template
premier jet de ce template de cartouche
    <!-- on commence par déclarer les images embarquées utilisables comme logos -->
    <logos>
        <!-- Solution basique pour embarquer des images non vectorielles : les insérer en base64 dans le XML -->
        <logo storage="base64" type="png" name="dott.png">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</logo>
        <logo storage="base64" type="png" name="qt.png">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</logo>
        <!-- L'intégration des logos SVG ne devrait pas poser de gros problème !-->
        <logo storage="xml" type="svg" name="test.svg">
            <svg width="300px" xmlns="http://www.w3.org/2000/svg" height="300px" xmlns:xlink="http://www.w3.org/1999/xlink">
                <title>Small SVG example</title>
                <circle cx="120" cy="150" style="fill: gold;" r="60"/>
                <polyline points="120 30, 25 150, 290 150" stroke="brown" style="fill: none;" stroke-width="4"/>
                <polygon points="210 100, 210 200, 270 150" style="fill: lawngreen;"/>
                <text x="60" y="250" fill="blue">Hello, World!</text>
            </svg>
        </logo>
        <!-- pas sur que l'attribut "type" soit indispensable, par contre -->
    </logos>
  Une fois qu'on a notre réserve de logos, on commence par définir notre cartouche comme une grille s'inscrivant dans un rectangle (= la place allouée au cartouche).
  La longueur de ce rectangle est inconnue (elle est héritée du schéma), et sa hauteur doit être fixée de manière absolue.
  On définit donc le nombre de colonnes et le nombre de lignes de la grille en entrant leurs dimensions séparées par des points-virgules.
  Les dimensions peuvent être exprimées de manière absolue en étant suivies de "px" pour pixels, mais aussi :
    - relativement a la longueur totale du rectangle, en étant suivies de "%" et précédées de "t" (pour "total" ; ce type de mesure est transcrit en mesure absolue des que la longueur du rectangle est connue)
    - relativement a la longueur totale du rectangle, duquel on soustrait la somme des dimensions absolues, en étant suivies de "%" et précédées de "r" (pour "remaining")
  Ce dernier type de mesure permet par exemple de réserver la place pour un logo (taille absolue), et de partager l'espace restant avec des mesures relatives
    <grid cols="40px;40px;80px;100px;100px;100px;120px;200px;150px;100px" rows="10px;10px;10px;10px;10px;10px;10px">
        <!-- On a donc ici défini deux lignes mesurant 30px chacune, soit une hauteur fixe de 60px pour le cartouche, mais aussi un espace fixe de 60px a gauche, tandis que le reste est partage entre trois espaces.
             On définit maintenant des champs et logos, en indiquant dans quelle case de la grille ils se logent (attributs row et col), et sur combien de cases supplémentaires ils s'étendent (attributs rowspan et colspan, valant 0 par défaut).
        <!-- pour les champs de texte, on distingue le nom du champ, son nom affiché (qu'on appelle "label", et qui peut être affiché //ou non// sur le cartouche) de sa valeur, systématiquement affichée, dont on ne mentionne que la valeur par défaut -->
        <field rowspan="0" row="0" col="0"/> label="revision" displaylabel="true" align="left"/>
        <field rowspan="0" row="0" col="1"/>
        <field rowspan="0" row="0" col="2"/>
        <field rowspan="0" row="0" col="3"/>
        <field rowspan="0" row="0" col="4"/>
        <field rowspan="0" row="0" col="7" value="%author" name="author" label="Auteur" displaylabel="true" align="left"/>
        <field rowspan="0" row="0" col="8" />
        <field rowspan="0" row="0" col="9" value="%date" name="date" label="Date" displaylabel="true" align="left"/>
        <field rowspan="0" row="1" col="0"/> label="revision" displaylabel="true" align="left"/>
        <field rowspan="0" row="1" col="1"/>
        <field rowspan="0" row="1" col="2"/>
        <field rowspan="0" row="1" col="4"/>
        <field rowspan="0" row="1" col="6"/>
        <field rowspan="0" row="1" col="7"/>
        <field rowspan="0" row="1" col="8"/>
        <field rowspan="0" row="1" col="9"/>
        <field rowspan="0" row="2" col="0"/>
        <field rowspan="0" row="2" col="1"/>
        <field rowspan="0" row="2" col="2"/>
        <field rowspan="0" row="2" col="3"/>
        <field rowspan="0" row="2" col="4"/>
        <field rowspan="2" row="2" col="6"/>
        <logo rowspan="4" row="0" col="5" resource="dott.png"/>
        <field rowspan="4" row="2" col="7"/>
        <field rowspan="0" row="2" col="8"/>
        <field rowspan="0" row="2" col="9"/>
        <field rowspan="0" row="3" col="0"/> label="d" displaylabel="true" align="left"/>
        <field rowspan="0" row="3" col="1"/>
        <field rowspan="0" row="3" col="2"/>
        <field rowspan="0" row="3" col="3"/>
        <field rowspan="0" row="3" col="4"/>
        <field rowspan="0" row="3" col="7"/>
        <field rowspan="0" row="3" col="8"/>
        <field rowspan="2" row="3" col="9" value="%{folio-id}/%{folio-total}" name="folio"  label="Folio"   displaylabel="true"  align="left"/>
        <field rowspan="0" row="4" col="0" label="D" displaylabel="true" align="left"/>
        <field rowspan="0" row="4" col="1"/>
        <field rowspan="0" row="4" col="2"/>
        <field rowspan="0" row="4" col="4"/>
        <field rowspan="0" row="4" col="7" label="8" displaylabel="true" align="left"/>
        <field rowspan="0" row="4" col="8" label="7" displaylabel="true" align="left"/>
        <field rowspan="0" row="4" col="9" label="8" displaylabel="true" align="left"/>
        <field rowspan="0" row="5" col="0" label="rev" displaylabel="true" align="left"/>
        <field rowspan="0" row="5" col="1"/>
        <field rowspan="0" row="5" col="2"/>
        <field rowspan="0" row="5" col="3"/>
        <field rowspan="0" row="5" col="4"/>
        <field rowspan="0" row="5" col="5"/>
        <field rowspan="0" row="5" col="7"/>
        <field rowspan="0" row="5" col="8"/>
        <field rowspan="0" row="5" col="9"/>
    </grid>
Explications:
donne un tableau de :10 colonnes (taille en px variables ) X 7 lignes de 10px
ensuite il suffit de remplir son tableau comme dans l'exemple plus haut
row=0 est la première ligne
col=0 est la première colonne
pour virer l'encadrement d'une cellule sois :
*1 ) on ne remplit pas la colone 5 en ligne 4 comme dans l'exemple ci dessous
        <field rowspan="0" row="4" col="3"/>
        <field rowspan="0" row="4" col="6" label="8" displaylabel="true" align="left"/>
*2) on joue avec le paramètre rowspan="x"
il fusionnera les x cellules en dessous
A vos clavier  :p
Vous pouvez nous envoyer vos réalisations (code)/screens
bonjour ,
La revision 1140 apporte dans l’éditeur de cartouche l'ajout  d'un menu pour integrer facilement votre logo et le coder en base64 , il accepte les images bitmap (png) et vectorielles ( svg) .
<logo storage="base64" type="png" name="150px-Logo_ds1.svg.png">iVBORw0KGgoAAAANSUhEUgAAAJYAAABmCAYAAAApk2j7AAAABmJLR0QA/wD/AP+gvaeTAAAAB3RJTUUH2AgbDDANLTwclwAAIABJREFUeJztXXd4VFXa/517p2UyyaSRHtIJZCYhIYTQQeqqqFiI67pi4xPBXbGtqI couic !!!
ensuite il suffit de l'ajouter dans le tableau comme ceci
<logo rowspan="4" row="0" col="5" resource="150px-Logo_ds1.svg.png"/>
exemple :
http://scorpio810.blogdns.net/generation-debian/qelectrotech/capture%20d&#039;%C3%A9cran8.png
voila @+
9 (edited by Brenda 2013-06-05 15:33:57)
These solutions are very usefu
