1 (edited by lowVoltage 2021-02-12 20:20:34)
Topic: SOLVED cannot save MENU > Settings > Configure QelectroTech
I am using presently QeT V 0.80-rc+c592b7a7fc957a06d79751d3 in Ubuntu.
Settings I enter for such properties as default text styles, language, etc at
[MENU > Settings > Configure QelectroTech]  are not retained upon the next time I open QelectroTech.
Is this typical?
Is there a solution for this?
Thank you for your attention.
2 (edited by bruce33 2021-02-12 08:25:35)
Re: SOLVED cannot save MENU > Settings > Configure QelectroTech
I use AppImage with Ubuntu 20.04 and I have no trouble.
What is your version of Ubuntu? Do you use AppImage?
Maybe you should delete the (corrupted?) config file: ~/.config/QElectroTech/QElectroTech.conf
3 (edited by lowVoltage 2021-02-12 10:08:40)
@bruce33,
To delete the configuration file (QelectroTech.conf), that is the correct solution.
Thank you for your attention to this matter!
Your help here is greatly appreciated.
(how to mark this discussion [SOLVED!]  ???)
in your initial post click on "edit", then modify the topic title.
