Topic: crashes on 0.8
Several crashes today.
here the log file.
(Qelectrotech V 0.8 on xubuntu 20.04)
QElectroTech → EN : Help, suggestions, discussions, ... → crashes on 0.8
here the log file.
Thanks for the log file.
It is good that we have the log file,i see we still need to clean up some Debug instructions in the code.
i also had crashes when saving with QT SDK in monitor but it couldn't point me to the error.
It is easy to say that the log file is useless, in fact we have to add even more on Debug instructions, especially when saving to know where things are going wrong.
it is perfectly possible that the error is in KF5 and not QET, but to find this ...
edited:
the saving is done with multithreading, and a lot can go wrong.
we might use "try catch" to prevent crashing
What did you do when crash occur ?
Most of the times it occurred on saving.
one time on editing an element's properties.
other times i don't remember.
Today i had about 4 or 5 crashes in 1 hour of job
yesterday in almost 2 hours not even a problem.
Please upgrade your version!
https://launchpad.net/~scorpio/+archive … tate=built
to upgrade is it sufficient to launch the "qelectrotech_0.80.r7109-2ubuntu2_amd64.deb" file, or should I uninstall first?
sudo apt-get update
sudo apt-get upgrade
That's all? Too easy. ![]()
Done. I will update you.
Generated in 0.019 seconds (26% PHP - 74% DB) with 12 queries
