1 (edited by scrouthtv 2020-10-26 20:46:49)
Topic: [SOLVED] Small lines next to connections
Hey everybody.
I just installed QET and tried using it to draw some basic circuits.
I connected some things by clicking the first terminal and dragging a connection to another terminal.
Now I've got a connection / wire, but also a small line next to it (I added the red outline afterwards):
https://i.imgur.com/sKEqynx.png
They also appear in an exported png.
Am I doing something wrong? How can I remove those?
Thanks for any help in advance.
Re: [SOLVED] Small lines next to connections
3 (edited by De-Backer 2020-10-26 18:23:13)
some info from the link:
The main difference of multiline with respect to single line conductors is the posibility to display text which is linked to the conductor properties.
Laurent, I think it's great that you've been keeping this up for years. I'll probably be crazy about all those simple questions.
Solved it.
In case anyone is experiencing the same issue, here is the solution:
Double-click each wire with a line next to it, and in the dialogue
1. Select "Single line" (will deselect Multiline)
2. Deselect all three "Ground", "Neutral" and "Phase"
3. Hit ok.
For a new project you can also set this in the configuration under "New Project" > "Conductor"
Double-click each wire with a line next to it, and in the dialogue and remove underscore or add your conductor label name!
For a new project you can also set this in the configuration under "New Project" > "Conductor" and remove the underscore by default!
