Topic: Apply Properties to All Conductors question
Hi There-
I think this is related to this function but I'm not sure.
I am wanting to give each wire a unique number.  What I find is wires downstream of say a terminal block inherit the upstream wire number or vice versa.
Is there a way to globally disable this feature or is there some sort of work around I'm not seeing.
Thank you so much!
Matt
Re: Apply Properties to All Conductors question
I am also facing that problem, if one wire's setting not was not deactivated, there would be lot of mass
