Topic: Terminal Block plugin does not start
I'm very new of automation in general and especially of qelectrotech.
In my case terminal block generator works just in the case I have just one terminal block (see attached inverter_trapano_colonna_1).
In the other case (inverter_trapano_colonna) the plugin does't start at all (I didn't see any windows for configuring the terminal block).
Why? Where am I wrong?
Thanks
2 (edited by S.DEFFAUX 2020-05-18 22:47:56)
Re: Terminal Block plugin does not start
Look at that nomicons/wink. your project clean
3 (edited by S.DEFFAUX 2020-05-18 22:49:26)
your projet with terminal block
Olá senhores. Preciso de ajuda na gestão de autonumeração do projeto. Ao alterar o status do projeto para concluído os elementos continuam com as formulas. Após esta alteração não deveria constar nos elementos somente a legenda sem a formula? Utilizo a QElectroTech V 0.80-DEV+0015f4a69d79751d3 no win10.
Desde já agradeço.
Segue exemplo do erro na numeração dos fios ao fechar o projeto. Quando é reaberto, algumas vezes este erro aparece. %seqt_1
Bonjour, j'ai un petit problème avec les borniers. Après avoir installé Python, quand je crée un projet, au début avec quelques bornes, la génération automatiques des borniers fonctionnent, mais après avoir rajouté des bornes ou d'autres borniers et après quelques jours d'enregistrements du projet, impossible de lancer le plugin de génération de bornier.
tu as bien suivis la procédure dans l'aide du générateur, avant de le lancer?
Steps to follow.
  - In QET, optional: Choose Project> Clean Project + save
  - In QET: Start the plugin. Choose 'Start the terminal block creation plug-in' in the project menu.
  - In this program: Edit the terminal blocks (described below).
  - In this program: Press the 'CREATE TERMINAL BLOCKS' button.
  - In this program: In the pop-up screen, choose the terminal blocks you want to create / update.
  - In this program: Close
  - In QET:  Close without saving project (very important) and reopen the project.
  - In QET: Under the 'COLLECTIONS' tree of the project, all the terminal blocks appear.
Moi c’est les cartouche qui le font beugger j’ai le même soucis
https://qelectrotech.org/forum/viewtopi … 8385#p8385
10 (edited by S.DEFFAUX 2020-05-25 19:46:26)
pour le problème viens des cartouches, J'ai du nettoyer moi-meme mon projet avec un éditeur de texte.
remonte le post: le premier project plante
                         celui que j'ai nettoyer fonctionne et mis dans mon poste fonctionne
Tu nettoies quoi ?
je supprime dans l'éditeur de texte la parti logo; Le texte surlignée
