Topic: Rotate terminal in editor?
Hello, I have searched the forum, and I have searched the help, but I can not find a way to rotate a terminal in the editor. Right mouse click does not have a "rotate".
Apparently it should exist, as it has been mentioned in the forum?
Thank you for your help.
Re: Rotate terminal in editor?
use space key when you drag and drop terminal.
On widget information you have orientation of terminal selected.
Thank you! That works - rotating the terminal before dropping it on the desktop.
https://download.qelectrotech.org/qet/m … rties.html
The good news is that from my limited understanding of unix, rotate seems to be doing what I expected rotate_all would be required to achieve. That is to say, setting just rotate and not rotate_all, seems to result in all local consoles being rotated anyway (i.e. alt + f1, alt + f2, etc are all rotated the same). shareit app
