Topic: the program hangs every 2 minutes
Hi everywone.
I am currently working with the latest stable version (0.7) in windows 10 64 bit.
It is becoming very difficult for me to work with my project of about 50 pages.
Every 2 or 3 minutes the program hangs for a few seconds.
Is there a solution to correct this problem?
Thanks.
2 (edited by Joshua 2020-03-30 12:59:16)
Re: the program hangs every 2 minutes
Hello david.
It's look like the auto-save hangs qet.
Go to settings -> configure QElectroTech -> general -> project and disabled "automatic backup of project" (the word is bad, it's not a backup but an autosave).
If when disabled qet continue to hangs, that  probably mean the problem come from the automatic backup, but in this case it's not possible to disabled it.
What's your hardware config ?
If problem continue I will see for add an option to disabled the auto-backup.
3 (edited by Joshua 2020-03-30 13:05:57)
Also you can try in parallel of QElectrotech 0.7, the 0.8 devel version, witch already came with some good new features.
See (in french) : https://qelectrotech.org/forum/viewtopi … 306#p10306
If you try 0.8-devel version copy and backup your's projects before and not mixing versions off QET in your projects.
A few week ago I posted something similar, about lagging of the pc.
https://qelectrotech.org/forum/viewtopic.php?id=1528
Maybe it inspires you to find your solution.
