Topic: Using folio properties from the project properties does not work
Hi
I have a project containing some folios.
I use a title block "a" with some variables in it, for example %pagename.
I have filled in this variable in the project properties.
When I create a new folio, these variable %pagename is automatically filled in, what is - of course - very welcome.
I have changed the language in my titleblock, what means I had to remove the title block "a" from my project en link the updated one "b" by creating a new folio, with the right title block "b" selected.
The problem now is that the variables in the titleblock "b" of my *existing* folios are not updated. This was what i was expecting actually.
Do I something wrong? Or aren't the existing folios not updated when reconnect a titleblock?
Re: Using folio properties from the project properties does not work
have you tried to put your project variables in project setting, like this?
https://download.qelectrotech.org/qet/forum_img/project_config_variables.png
https://download.qelectrotech.org/qet/forum_img/project_settings.png
3 (edited by MvanEIjk 2020-03-13 08:02:05)
I struggled around for some time but finally I saw what went wrong.
I really was thinking that the wished variable had to be in the folio TOO.
No wonder that these variable wasn't updated after I changed the value of that same variable in the project properties.
Anyway, tldr, as soon as I deleted the variable in the folio, it works like a charm!
The folio variable is - as I learned - overruling the property variable.
French explanations :
https://qelectrotech.org/forum/viewtopi … 4703#p4703
