Topic: Element Editor Question
Hi There-
Is there a method of rotating elements in the Element editor?
Thanks
Matt
QElectroTech → EN : Help, suggestions, discussions, ... → Element Editor Question
Hi There-
Thanks
Matt
not in editor, but element is easy to rotate on your folios whit key space.
Thanks for the reply!
Is there a preference or function thought that will auto rotate text in a element when you rotate it in the folio? I have to go edit the element and manually rotate the text.
Thanks!
Matt
Yes function " do not rotate element texts when element is rotated" existed before, but deleted since so complicate useless the code with dynamic texts.. and no one was using this function ...
Got it thank you!
Generated in 0.039 seconds (13% PHP - 87% DB) with 12 queries
