Topic: error on new element uuid (AMD Ryzen)
the uuid element is always {ffffffff-ffff-4fff-bfff-ffffffffffff} if a new element is created
info: in QT on startup
WARNING: CPU random generator seem to be failing, disable hardware random number generation
WARNING: RDRND generated: 0xffffffff 0xffffffff 0xffffffff 0xffffffff
https://www.google.com/search?q=WARNING … 0xffffffff
AMD shipped Ryzen 3000 with a serious microcode bug in its random number generator.
QElectroTech_0.8-DEV-r6091-x86_64
openSUSE TW 20191214
Can I adjust the uuid myself in the project?
Re: error on new element uuid (AMD Ryzen)
yes but, the element uuid is in the library and in the project.
I am trying to updating the BIOS
https://qelectrotech.org/forum/viewtopi … 7221#p7221
You could try to upgrade your AMD microcode package. (amd64-microcode (3.20191218.1))
Or maybe upgrade to latest 5.4.6 vanilla kernel..
https://codereview.qt-project.org/c/qt/qtbase/+/272837
Hi, this was my mistake the element library was made with QElectroTech V0.61, and converted with V0.8 with the failed CPU.
(suse provides QElectroTech Version 0.61 standard.)
I tried is unsuccessful.
This will break my virtualbox.
(ps: updating the BIOS works)
Thank you for the support.
you have AppImages if you want new versions, just wget and chmod +x.
Virtualbox Version 6.1.0 r135406 (Qt5.12.5) run on 5.4.6 kernel.
