Topic: conductor line end property
Is it possible to config the line end property (arrow, circle, diamond ) for a conductor (as inside Element Editor)? If not, is there a way to add? Thanks!
QElectroTech → EN : Help, suggestions, discussions, ... → conductor line end property
Not for the moment, but you could connect a end symbols at the end of conductor like (arrow, circle, diamond ) or what you want.
Is there a plan to add the function in the near future? It will be a very useful feature not only for schematics but also for general diagram making.
"connect a end symbol at the end of conductor", does the "symbol" mean I have to make an user defined element which contains arrow, circle or diamond?
Thanks!
Yes. It is pretty easy to make own elements
Generated in 0.018 seconds (26% PHP - 74% DB) with 10 queries
