Topic: Label position do not follow conductors well... bug?
When moving a conductor
(or moving an element so conductors follow)
then the conductor labels follow
BUT
Most often not not if i have adjusted label position i.e to center or other side of conductor.
This may be intentional behaviour and not a bug, but i think it would be much better if the label would be moved relative; follow the move of the conductor.
This is what i am use to from other editors.
Currently, moving elements around "scatters" conductor labels around in some chaotic order...
Thinking... Maybe it would be best internally solved by storing separately how much user have moved labels it from default position, so it can always recalculate new position from current conductor position and that ofset, and need not keep track and update at high speed.
