Topic: Ability conductor size less than 1
I wan to add ability to change conductor size less than 1 and have edit some source (diff. attached), but when i set conductor size set to 0.2, 0.4, or 0.6 it always displayed equally tiny.
am i miss any required code to edit?
Re: Ability conductor size less than 1
thank you for your patch, but I think your conductor isn't visible after printing.
See my corrected patch. ;-)
minimum">0.40 px
maximum">10.0 px
Step">0.20 px
value">1.00 px (default)
Revision: 4605
Author:   scorpio810
Date:     2016-08-05 14:15:59 +0200 (Fri, 05 Aug 2016)
Log Message:
Add ability conductor size less than 1, thank Timbul Widodo
scorpio810 thank you for correction,
but i am not yet understand, if we look at diagram closely there are no difference when we set conductor size to 0.2 and 0.8
Are you tried to print?
The conductor size you view in diagram is depend to zoom factor.
// utilisation d'un trait "cosmetique" en-dessous d'un certain zoom
    if (options && options -> levelOfDetail < 1.0) {
        final_conductor_pen.setCosmetic(true);
yes i am,
I am using
Qt Creator 3.5.1 (opensource)
Based on Qt 5.5.1 (MSVC 2013, 32bit)
On Windows 7
laurent@debian:~$ qtcreator -version
Qt Creator 4.0.2 based on Qt 5.6.1
On Debian unstable (X86_64)
just founded
Attachment icon 0003.diff 556 b, 492 downloads since 2016-08-06
Revision: 4607
Author:   scorpio810
Date:     2016-08-06 12:58:56 +0200 (Sat, 06 Aug 2016)
Log Message:
Fix conductor size less than 1, thanks Timbul Widodo
