1 (edited by rdsivd 2016-01-31 23:19:47)
Topic: Found a something strange into version 0.51-dex+svn4334 (win10)
Select a symbol on a page of your project
then edit the element (a user element), save your change and go back to your project
nothing changed on your project symbol
save your project, close it and the reopen it
the symbol is disappears on your project page
when you do the same editing into the imported elements of your project the use element on page also disappears
if i edit a elmt save it and then do a litle change on page and the click on save then the elmt stays on your page
so when you edit a elmt and saves that elmt in the element editor there is no signal given to the project you are working on that there is something changed on your page!!!
Re: Found a something strange into version 0.51-dex+svn4334 (win10)
Update element panel by press touch F5.
Drag and drop element last edit on your diagram.
A message appear choose overwrite previous element.
Now element is replaced by new.
Ok,
i did not removed the one that was draw on my page
when inserting a new symbol like you tell, then i have to remake all the connection ?
it works easyer if the save symbol is active after editing a element of a page
i force this by change something of the connecions than i can click on save project
and the next time i open the project the symbol is update without lossing al the connection of the symbol
