Topic: File erased
I am using Qelectrotech 0.5-b and the program closed by itself, like it does sometimes. and the file is now epmty (0kb my computer tells me) and the program crashes when i try to open it.
Does someone has any idea how to solve this problem. I really don't want to start again.
Thanks
Re: File erased
It bugged while saving, so isn't there a temporary file that stores the file while erasing the original, in which i could recover all the information?
Re: File erased
No tempory file sorry, but I used to increment backup on big projects or when I test functions, or hacking by save as to increment name.
Example :
ls -al | grep parc_bois
-rw-r--r--  1 laurent laurent  3483075 janv. 18  2015 parc_bois11.qet
-rw-r--r--  1 laurent laurent  3633957 janv. 21  2015 parc_bois12 1.qet
-rw-r--r--  1 laurent laurent  3923492 janv. 28  2015 parc_bois122.qet
-rw-r--r--  1 laurent laurent  3671139 janv. 21  2015 parc_bois12.qet
-rw-r--r--  1 laurent laurent  3961692 mai   24 16:37 parc_bois15.qet
-rw-r--r--  1 laurent laurent  3971817 janv. 31  2015 parc_bois16.qet
-rw-r--r--  1 laurent laurent  4856941 févr. 10  2015 parc_bois18.qet
-rw-r--r--  1 laurent laurent  4837050 févr. 21  2015 parc_bois19.qet
-rw-r--r--  1 laurent laurent  6215147 mai   24 17:18 parc_bois24.qet
-rw-r--r--  1 laurent laurent  6901745 août  15 14:06 parc_bois25.qet
-rw-r--r--  1 laurent laurent  1886157 déc.   5  2014 parc_bois2.qet
-rw-r--r--  1 laurent laurent  2486496 déc.   9  2014 parc_bois3.qet
-rw-r--r--  1 laurent laurent  2548687 déc.  16  2014 parc_bois4.qet
-rw-r--r--  1 laurent laurent  2883838 déc.  17  2014 parc_bois5.qet
-rw-r--r--  1 laurent laurent  3098464 déc.  18  2014 parc_bois6.qet
-rw-r--r--  1 laurent laurent  3112912 déc.  19  2014 parc_bois7.qet
-rw-r--r--  1 laurent laurent  3476316 janv. 11  2015 parc_bois8.qet
-rw-r--r--  1 laurent laurent  5611938 févr. 22  2015 parc_bois9.qet
-rw-r--r--  1 laurent laurent   999215 nov.  18  2014 parc_bois.qet
Re: File erased
You remember what action you make for to Qet crash?
Re: File erased
No action, I just saved. but it was crashing a lot before that. mabe it's because i am puting a lot of images in the file. mabe it's too heavy for the program I don't know.
Or mabe I should try to reduce the resolution of the pictures
Re: File erased
Ok, i see.
When you import a image it is converted to base64 in code and in your project .qet, and yes isn't a perfect solution for a lot of big image.
Other problem, image converted is weighty than original.
http://stackoverflow.com/questions/7467 … o-xml-file
Re: File erased
What do you mean  with the link?
Re: File erased
XML is not a format for storing images..
You can but you do prefer drawing element yourself. nomicons/smile
If you use 60 images and in high resolution in your project, perhaps possible crash..
Re: File erased
i tried this test in new project with ~ 90 folios and paste the same 270 Kio image in every folio....
i don't see any problem, but i use a machine with 16 Gio of ram,  big AMD eight core (FX8350), on GNU/Linux full 64 bit, now project  85Mio  weighs... Perhaps saving the same test on Windows 32 Bits machine can make a empty project..
The only bug i found : if we  don't save this project before, after putting all images :
interface no longer responds and don't ask menu to select folder and file to save, and you must kill Qet process..and lose your work!
Re: File erased
sometimes it takes very long, even halting other programs so be patient, and yes i have them about once every day in simple windows.
but it is a free program so why complain.
paul deelen
shooter@home.nl
