Topic: version 0.5-dev+4001-1/0.5-dev+4003-1/
Hello
Could it be that these two trials in the ladder to connect the label
References not working. In the version 0.5-dev + 3997-1 no problems.
With best regards
Stebo
QElectroTech → EN : Help, suggestions, discussions, ... → version 0.5-dev+4001-1/0.5-dev+4003-1/
Hello
With best regards
Stebo
The only problem in 0.5-dev+4003 is for report folio, conductor name isn't refreshed when you link report.
I Just tried the latest 0.5 build,
I think there is a bug :
I can't assign a label text to an element, & you can't save elements because of the missing Label
can you check this pls
Fixed now, and new packages is availables. (svn 4076)
Uploaded new packages (svn 4078), fix basic shapes items.
Generated in 0.043 seconds (32% PHP - 68% DB) with 10 queries
