1 (edited by Silvio 2013-06-24 17:40:12)
Topic: Language selection
Is possible to add the language selection?
In "Configurer QElectroTech", inserted between "apparence" and "projects".
It would be useful if the system language is not their own language, or to verify translation problems.
Silvio
Re: Language selection
Hi Silvio,
On linux platform Qet by default detect locale system, but you can run Qet in other language by :
just run in a terminal
for example :
german
LANG=de_DE qelectrotech
italian
LANG=it_IT qelectrotech
english
 LANG=en_EN qelectrotech
It run Qet in the language that you want
[09:14:05] laurent@debian:~$ LANG=en_EN qelectrotech
transaction began for  "common"
transaction commited for  "common"
transaction began for  "custom"
transaction commited for  "custom"
As usual, for me, don't work :-(
I receive this message:
Gtk-WARNING **: Locale not supported by C library.
    Using the fallback 'C' locale.
does Qet start as german if you start as follows:
$ LANG=de_DE.utf8 qelectrotech
5 (edited by Silvio 2013-06-24 19:37:37)
No, it is always in Italian.
But this is the terminal:
http://forums.debian.net/viewtopic.php?f=6&t=103163
7
why not, but two method are possible:
Change language at runtime or translate on fly
http://qt-project.org/wiki/How_to_creat … pplication
http://www.informit.com/articles/articl … p;seqNum=3
but I prefer to use our time to add business functions already asked :p
I'll add it anyway todo for version 0.4
Regards
8
in windows OS a workaround is possible to change language setting at runtime just
[12:22:12] laurent@debian:~/qet_directory/misc$ grep REDEFINE launch_qet.sh
# REDEFINE_LANG="es"
if [ "${REDEFINE_LANG}" ]; then
        export LANG="${REDEFINE_LANG}"
[12:24:07] laurent@debian:~/qet_directory/misc$
change
by
REDEFINE_LANG="it"
after run Lancer QET.bat
http://qelectrotech.org/wiki/en/doc/tra … ranslation
10
Hi Silvio,
Done
Revision: 2762
Author:   blacksun
Date:     2014-01-21 20:23:44 +0100 (Tue, 21 Jan 2014)
Log Message:
Add widget to select langage, must relauch qet for make change
Debian packages are availables.
https://download.qelectrotech.org/qet/forum_img/switch_language2.png
11
Hi Silvio,
Since the commit 2772 (I think scorpio will build it soon)
If you need change langage in qet for translate the elements, no need to relaunch it, just reload the collection.
This commit just work for elements, none for titleblocks or main windows.
12 (edited by teknikyedek 2017-06-06 00:34:46)
Çok hoş program ama türkçe olsa da şahane olurdu nomicons/smile
Very nice program but it would be great if it was turkish
13
Thank you. nomicons/smile
If you know someone for this job?
