Topic: Uneven printed conductor strokes and dense PE dash-dot pattern
I am using QElectroTech 0.100.0 on Windows 11, built and running with Qt 5.15.18, x86_64.
I have two questions about native electrical conductors.
Uneven printed appearance
The conductors have the same Appearance settings: black, Size 0.50, secondary colour disabled. Nevertheless, some lines appear thicker or darker than others in PDF output and on paper.
Export to PDF produces vectors and looks better than printing through a PDF printer, which produces image objects. However, the unequal appearance is not completely eliminated.
The project was generated programmatically from an existing drawing, using native QET elements and conductors. Could overlapping conductor segments, symbol connection strokes or a rendering setting explain this? What would be the best way to distinguish a project problem from a PDF/printer rendering problem?
PE dash-dot spacing
The native dash-dot pattern is too dense at the required thin line width. I need a long dash, clear gap, dot, clear gap, repeated.
Can the dash and gap lengths be adjusted independently of conductor thickness while retaining a real electrical conductor that follows connected elements?
I found the older “Project Scale” discussion, but its Custom dash line suggestion appears to concern graphical shapes.
Is there an existing setting, newer fix or patch for either issue? If independent conductor dash spacing is not supported, should I submit a feature request?
I can provide a reduced .qet example, the exported vector PDF and photographs of the printed result.
Thank you for your help.
