Topic: Problems with some default variables
Hi. I am using the version "0.100.1-dev" of QElectroTech.
I meet theses problems:
1) "projecttitle" is not set by setting the "Project title" text field of the "Project properties" window.
2) "saveddate" is not set whereas "savedtime" is set.
3) "saveddate-eu" is not set.
4) The format of "date" is "dd/mm/yy". Is there a way in order to obtain the creation date of folio in a different format, for example "dd/mm/yyyy"?
Thanks for any answer.
Massimo Lo Iacono
