import xml.etree.ElementTree as ET
import tkinter as tk
from tkinter import filedialog, messagebox
import os
class QETRenumberingApp:
def __init__(self, root):
self.root = root
self.root.title("Numérotation de Fils QElectroTech")
self.root.geometry("700x550")
# Variables de données
self.file_path = None
self.tree = None
self.root_xml = None
self.folios = [] # Liste des éléments <diagram>
# --- Interface Graphique ---
# Section Fichier
frame_file = tk.LabelFrame(root, text="Fichier Projet")
frame_file.pack(fill=tk.X, padx=10, pady=5)
self.btn_open = tk.Button(frame_file, text="Ouvrir fichier .qet", command=self.open_file)
self.btn_open.pack(side=tk.LEFT, padx=5, pady=5)
self.lbl_file = tk.Label(frame_file, text="Aucun fichier sélectionné", fg="gray")
self.lbl_file.pack(side=tk.LEFT, padx=5)
# Section Liste des Folios
frame_list = tk.LabelFrame(root, text="Sélection du Folio")
frame_list.pack(fill=tk.BOTH, expand=True, padx=10, pady=5)
self.listbox_folios = tk.Listbox(frame_list, selectmode=tk.SINGLE, font=("Consolas", 10))
self.listbox_folios.pack(side=tk.LEFT, fill=tk.BOTH, expand=True, padx=5, pady=5)
scrollbar = tk.Scrollbar(frame_list, orient="vertical", command=self.listbox_folios.yview)
scrollbar.pack(side=tk.RIGHT, fill=tk.Y)
self.listbox_folios.config(yscrollcommand=scrollbar.set)
self.listbox_folios.bind('<<ListboxSelect>>', self.on_folio_select)
# Section Options
frame_options = tk.LabelFrame(root, text="Paramètres de Numérotation")
frame_options.pack(fill=tk.X, padx=10, pady=5)
tk.Label(frame_options, text="Préfixe :").grid(row=0, column=0, padx=5, pady=5, sticky="e")
self.entry_prefix = tk.Entry(frame_options, width=10)
self.entry_prefix.grid(row=0, column=1, padx=5, pady=5, sticky="w")
self.entry_prefix.insert(0, "") # Vide par défaut
tk.Label(frame_options, text="Format :").grid(row=0, column=2, padx=15, pady=5, sticky="e")
self.var_format = tk.StringVar(value="0")
tk.Radiobutton(frame_options, text="0, 1, 2...", variable=self.var_format, value="0").grid(row=0, column=3)
tk.Radiobutton(frame_options, text="00, 01, 02...", variable=self.var_format, value="00").grid(row=0, column=4)
tk.Label(frame_options, text="Début :").grid(row=1, column=0, padx=5, pady=5, sticky="e")
self.entry_start = tk.Entry(frame_options, width=10)
self.entry_start.grid(row=1, column=1, padx=5, pady=5, sticky="w")
self.entry_start.insert(0, "0")
self.btn_set_08 = tk.Button(frame_options, text="Mettre 08", command=lambda: self.set_start_value("08"))
self.btn_set_08.grid(row=1, column=2, padx=5, pady=5, sticky="w")
# Section Actions
frame_actions = tk.Frame(root)
frame_actions.pack(fill=tk.X, padx=10, pady=10)
self.btn_process = tk.Button(frame_actions, text="Numéroter le folio sélectionné", command=self.process_folio, state=tk.DISABLED, bg="#dddddd", height=2)
self.btn_process.pack(side=tk.LEFT, fill=tk.X, expand=True, padx=5)
self.btn_save = tk.Button(frame_actions, text="Sauvegarder le projet sous...", command=self.save_file, state=tk.DISABLED, height=2)
self.btn_save.pack(side=tk.RIGHT, fill=tk.X, expand=True, padx=5)
def set_start_value(self, val):
self.entry_start.delete(0, tk.END)
self.entry_start.insert(0, val)
def open_file(self):
path = filedialog.askopenfilename(filetypes=[("Projet QElectroTech", "*.qet"), ("Fichiers XML", "*.xml")])
if path:
self.file_path = path
self.lbl_file.config(text=os.path.basename(path), fg="black")
self.parse_qet()
def parse_qet(self):
try:
self.tree = ET.parse(self.file_path)
self.root_xml = self.tree.getroot()
self.folios = []
self.listbox_folios.delete(0, tk.END)
# Recherche des diagrammes (folios)
for i, diagram in enumerate(self.root_xml.findall('diagram')):
title = diagram.get('title', 'Sans titre')
# Essayer de trouver le numéro de folio, sinon utiliser l'index
num = diagram.get('folio', str(i + 1))
label = f"N° {num} : {title}"
self.folios.append(diagram)
self.listbox_folios.insert(tk.END, label)
self.btn_save.config(state=tk.NORMAL)
self.btn_process.config(state=tk.DISABLED)
except Exception as e:
messagebox.showerror("Erreur", f"Impossible de lire le fichier :\n{e}")
def on_folio_select(self, event):
if self.listbox_folios.curselection():
self.btn_process.config(state=tk.NORMAL, bg="#aaffaa") # Vert clair quand actif
# Réinitialiser le début selon le format
default_val = "00" if self.var_format.get() == "00" else "0"
self.entry_start.insert(0, default_val)
else:
self.btn_process.config(state=tk.DISABLED, bg="#dddddd")
def process_folio(self):
idx = self.listbox_folios.curselection()
if not idx:
return
diagram = self.folios[idx[0]]
prefix = self.entry_prefix.get()
fmt = self.var_format.get()
try:
start_num = int(self.entry_start.get())
except ValueError:
start_num = 0
try:
count = self.renumber_wires_logic(diagram, prefix, fmt, start_num)
messagebox.showinfo("Succès", f"Folio renuméroté avec succès.\n{count} équipotentielles traitées.")
messagebox.showerror("Erreur", f"Une erreur est survenue lors de la numérotation :\n{e}")
def get_definitions(self, root_xml):
definitions = {}
collection = root_xml.find('collection')
if collection is None:
return definitions
def traverse(element, current_path):
for child in element:
if child.tag == 'category':
name = child.get('name')
new_path = f"{current_path}/{name}" if current_path else name
traverse(child, new_path)
elif child.tag == 'element':
uri = f"embed://{current_path}/{name}" if current_path else f"embed://{name}"
definition = child.find('definition')
if definition is not None:
definitions[uri] = definition
traverse(collection, "")
return definitions
def renumber_wires_logic(self, diagram, prefix, fmt, start_num=0):
# 0. Index definitions
definitions = self.get_definitions(self.root_xml)
# 1. Identification des bornes de continuité et positions des terminaux
continuity_uuids = set()
terminals_pos = {} # (element_uuid, terminal_uuid) -> (x, y)
elements_pos = {} # uuid -> (x, y) pour position par défaut
for elem in diagram.findall('elements/element'):
uuid = elem.get('uuid')
type_uri = elem.get('type', '')
# Stockage position pour tri géométrique si le fil n'a pas de points
try:
x = float(elem.get('x', 0))
y = float(elem.get('y', 0))
elements_pos[uuid] = (x, y)
except:
continue
# Détection borne continuité
if 'continuite' in type_uri.lower():
continuity_uuids.add(uuid)
# Parse terminals from definition
def_node = definitions.get(type_uri)
if def_node is not None:
# Check link_type in definition if needed
if 'continuite' in def_node.get('link_type', '').lower():
for term in def_node.findall('description/terminal'):
t_uuid = term.get('uuid')
if t_uuid:
try:
t_x = float(term.get('x', 0))
t_y = float(term.get('y', 0))
terminals_pos[(uuid, t_uuid)] = (x + t_x, y + t_y)
except:
pass
# 2. Construction du graphe de connexions (Union-Find)
conductors = diagram.findall('conductors/conductor')
parent = list(range(len(conductors)))
def find(i):
if parent[i] == i: return i
parent[i] = find(parent[i])
return parent[i]
def union(i, j):
root_i = find(i)
root_j = find(j)
if root_i != root_j:
parent[root_i] = root_j
# Dictionnaire : (ElementUUID, TerminalUUID) -> Liste d'index de conducteurs
terminals_map = {}
for i, cond in enumerate(conductors):
# Récupération des extrémités du fil
e1_uid = cond.get('element1')
t1_uid = cond.get('terminal1')
e2_uid = cond.get('element2')
t2_uid = cond.get('terminal2')
# Enregistrement des connexions
for e_uid, t_uid in [(e1_uid, t1_uid), (e2_uid, t2_uid)]:
if not e_uid: continue
# Si c'est une borne de continuité, on ignore le terminal spécifique
# pour considérer que tout ce qui touche cet élément est connecté.
if e_uid in continuity_uuids:
key = (e_uid, 'COMMON_POTENTIAL')
else:
key = (e_uid, t_uid)
if key not in terminals_map:
terminals_map[key] = []
terminals_map[key].append(i)
# Fusion des groupes (Union)
for key, indices in terminals_map.items():
base = indices[0]
for other in indices[1:]:
union(base, other)
# 3. Regroupement par équipotentielle
groups = {}
root = find(i)
if root not in groups:
groups[root] = []
groups[root].append(cond)
# 4. Filtrage et Tri
equipotentials_to_process = []
for root, group in groups.items():
# Vérifier si l'équipotentielle est déjà numérotée (verrouillée)
# On ignore si un des fils a un numéro qui n'est pas "" ou "_"
is_locked = False
for cond in group:
num = cond.get('num', '')
if num and num != "_":
is_locked = True
break
if is_locked:
continue
# Calcul de la position (le point le plus en haut à gauche de tout le réseau)
min_x = float('inf')
min_y = float('inf')
for cond in group:
# Vérifier les points du tracé du fil
points = cond.findall('point')
if points:
for pt in points:
px = float(pt.get('x', 0))
py = float(pt.get('y', 0))
if px < min_x: min_x = px
if py < min_y: min_y = py
else:
# Si pas de points (connexion directe), utiliser la position des terminaux
e1 = cond.get('element1')
t1 = cond.get('terminal1')
if e1 and t1 and (e1, t1) in terminals_pos:
tx, ty = terminals_pos[(e1, t1)]
if tx < min_x: min_x = tx
if ty < min_y: min_y = ty
elif e1 and e1 in elements_pos:
ex, ey = elements_pos[e1]
if ex < min_x: min_x = ex
if ey < min_y: min_y = ey
e2 = cond.get('element2')
t2 = cond.get('terminal2')
if e2 and t2 and (e2, t2) in terminals_pos:
tx, ty = terminals_pos[(e2, t2)]
elif e2 and e2 in elements_pos:
ex, ey = elements_pos[e2]
# Sécurité si infini
if min_x == float('inf'): min_x = 0
if min_y == float('inf'): min_y = 0
equipotentials_to_process.append({
'wires': group,
'x': min_x,
'y': min_y
# Tri : Haut en Bas (y), puis Gauche à Droite (x) pour un balayage par ligne.
equipotentials_to_process.sort(key=lambda e: (e['y'], e['x']))
# 5. Application de la numérotation
counter = start_num
for eq in equipotentials_to_process:
# Formatage du numéro
num_part = str(counter)
if fmt == "00" and counter < 10:
num_part = "0" + num_part
label = f"{prefix}{num_part}"
# Mise à jour de tous les fils du groupe
for cond in eq['wires']:
cond.set('num', label)
# Note: QET met à jour l'affichage automatiquement basé sur l'attribut 'num'
counter += 1
return len(equipotentials_to_process)
def save_file(self):
if not self.tree: return
path = filedialog.asksaveasfilename(defaultextension=".qet", filetypes=[("Projet QElectroTech", "*.qet")])
if path:
try:
self.tree.write(path, encoding="UTF-8", xml_declaration=True)
messagebox.showinfo("Sauvegardé", f"Fichier sauvegardé :\n{path}")
messagebox.showerror("Erreur", f"Erreur lors de la sauvegarde :\n{e}")
if __name__ == "__main__":
root = tk.Tk()
app = QETRenumberingApp(root)
root.mainloop()
