Topic: MS XMLNotepad is a good companion when working inside QET
Tip:
MS XMLNotepad is a good companion when working with QET.
https://github.com/microsoft/XmlNotepad
You can open the .qet file directly (no need to change file ext to .xml)
Whenever you have saved from QET, XMLNotepad asks if you wish to reload the file.
Data can be edited in sort of a "table mode"
Works "side by side"
