Topic: it does not look like a Qelectrotech
hello when trying to open a schematic a message appears saying it is impossible because "it does not look like a Qelectrotech project".
how can I open the schematic in this case? I have already tried to open the program first and then search for the end. I also tried to copy the file to another destination and then try to open it again but without success. thanks
Re: it does not look like a Qelectrotech
maybe you can share your project here if your file isn't empty!
Edit your first message and you'll see the file import button.
This is the message, when the file is broken!
QET saves it's data in XML-files and (like many others!) does not show where the problem might be, when loading fails.
Try to open a copy of that file (renamed to *.xml) with firefox: It shows the first problematic part, that you have to fix. This might have to be repeated several times, before the XML is valid.
In a CMD-Window you can also use the most recent version of QET_ElementScaler, where the first problematic part of the file will be shown:
usage:
QET_ElementScaler SchematicFile.qet
It might show something like this:
$ QET_ElementScaler filtre-à-bande.qet
File "filtre-à-bande.qet" could not be loaded: Error parsing element attribute
Check file up to byte-offset: 1196545 -- content partly shown here:
(...)rmula="" y="-130" numsize="7" condsize="1" conductor_colo" condsize="1" freezeLabel="false" bus="" dash-size="2" y="(...)
