Topic: renumber wiring
Is there any way to renumber the numbering of the wiring already done?
Context: Sometimes I have project reviews, where there is a need to renumber the wiring in a certain section.
Tks for help.
QElectroTech → EN : Help, suggestions, discussions, ... → renumber wiring
Tks for help.
I'm extremely new here, so you can likely take me with a grain of salt. With that said, I saw a different post requesting changing to the autonumbering setup that essentially said there isn't currently a way to do that. In that post someone had referenced some high level user/developer of this software stating that person doesn't use the autonumbering feature because of similar issues to that.
After I'd read that post I essentially just setup numbering and labeling for everything with a %f-%c%l type of formula, then at the end go through and individually update the numbers. I'm not sure of the size of projects you're working with, but this would help to only have to update a sheet at a time potentially.
Generated in 0.017 seconds (26% PHP - 74% DB) with 10 queries
