Topic: Text editor
In new element mode TEXT properties are in Information Mode
In normal drawing mode TEXT properties are in Selection Mode
Different set up Between 2 properties ?
Is there anyway to unsnap text so that I can move to position of choice
IF I have text inside terminal block I cannot copy and paste in drop down menu but can copy and paste using keyboard
Ctrl + C ?
Martin
Suggestion to next update to improve TEXT editing and have relay coil with 2K1 and have relay contacts being able to move below relay coil
need scaling drawings for example how to draw a terminal of 36mm x 3.5mm  (ZDU 1.5 terminals)
GRID size cannot be changed in new element mode as same as normal drawing mode .
Hope you can follow sorry my english is not perfect !
martin
