Topic: The program hangs cyclically every 8-15 minutes for 1-2 minutes
I have already switched off autosaving. On the PC I have set the energy options
set to Max.
I have also tried older versions, always the same.
It is not possible to work properly with this program
Lenovo Thinkpad P50
Two SSDs are installed in the Raid 0 array in the computer
QElectroTech V 0.90
Compilation: GCC 11.3.0
Built with Qt 5.15.7 - x86_64 - Date : Jan 6 2023 : 12:55:49
Run with Qt 5.15.7 using 8 thread(s)
CPU : NAME INTEL(R) CORE(TM) I7-6820HQ CPU @ 2.70GHZ
RAM Total : 65 GB
RAM Available : 59 GB
GPU : VideoProcessor Quadro M2000M Intel(R) HD Graphics Family
GPU RAM : RAM Total : AdapterRAM 4293918720 1073741824 B
OS : winnt - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19045
Windows 10 has all available updates
All other programs I use run without problems
Translated with DeepL.com (free version)
Re: The program hangs cyclically every 8-15 minutes for 1-2 minutes
Have you tried on other machine?
Please try with last 0.100-devel version, and saw log file in help menu -> About QElECtroTech, -> tab logs.
https://download.qelectrotech.org/qet/forum_img_2/log_tab_de.png
Otherwise launch qelectrotech from a terminal it will be more verbose to find out what's going on..
Yes, I have tried another computer. On my MacBook 13” M1 16GB Ram
the program behaved exactly the same as on the Windows computer
I will try the 0.100-devel version and watch the logfile
Thanks for the hint
Please try also 0.100-devel arm64 "package for Apple Siicon" on your MacBook, not the package x86_64 for macOS intel.
Yes
I will try that out too
Download arm64 Apple silicon only with Safari, other programs break some thing in the notharization stamp:
https://qelectrotech.org/forum/viewtopic.php?id=2635
https://qelectrotech.org/forum/viewtopic.php?id=2537
I have tried version 0.100 (DEV). Attached is the log file. In the section "exporting diagram \"MDT Sc...."
I had a program hang. I cannot say what the program is doing there.
I still have to test the CAD program version 0.100 on my Mac
I have also tried version 0.100 DEV on my Mac. It also looks as if the program hangs briefly at the lines
15:30:56.426 Debug: Export XML de 30 schemas (sources/qetproject.cpp:954, QDomDocument QETProject::toXml())
15:30:56.427 Debug: "exporting diagram \"cover sheet\"" [ Diagram(0x128e0b5a0) ] (sources/qetproject.cpp:959, QDomDocument QETProject::toXml())
15:30:56.459 Debug: "exporting diagram \"Feed\"" [ Diagram(0x1153ebbd0) ] (sources/qetproject.cpp:959, QDomDocument QETProject::toXml())
Perhaps especially with the line
I will continue to monitor it
could be exactly like the Windows version
Maybe please share your project!
BTW, if you have a lot of pictures with big size, is normal...
I have deleted all photos from the circuit diagram. I had the photos in the plan for a more detailed explanation.
Since the photos have been deleted from the circuit diagram, I have not had the error again.
Thank you very much for the effort and help, I can work very well with the program
Many thanks
