Topic: Summary - Nomenclature SQL Query Table, adjusting Column Width
Tried searching this one to see if anyone had found a solution. It looks like someone might have using printf().
https://qelectrotech.org/forum/viewtopic.php?id=2464
I just created separate tables for each column but kept the rest of the statement the same and then modified the tables independently, this allows me to click and drag in order to modify the table columns and gives the illusion that it is 1 Table.
https://autumn.revolt.chat/attachments/DgjuDqy9AyJgXuive7QQbUw0bDqrFZlc0CL8HHFOuO/screenshot0002.png
Re: Summary - Nomenclature SQL Query Table, adjusting Column Width
Just an additional note, it becomes a bit buggy when allowing it to automatically create additional folios with more than 1 table. The work around I found is to disallow this and create the tables manually and manually linking them.
