Topic: Documentation sur les Variables
Avez vous un document regroupant toutes les variables implémenté de base dans un projet ?
Nous avons par inadvertance découvert quelques variables, notamment sur les numéros de folio (%id), mais il en existe peut être d'autres qui pourraient nous être utiles.
Merci de votre réponse et bonne journée.
Benoit Charpentier
Re: Documentation sur les Variables
 * Inside this namespace you will fin all information used in QElectrotech for
 * element, conductor and diagram.
 * Each information have 3 values :
 * #1 the info key = the key of an information as a QString used in the code (example : label)
 * #2 the info key to variable = the key in form of a variable.
 * This is used by the user to replace a variable by the string of this variable (example : %{label})
 * #3 the info key translated to the current local (example label in dutch = Betriebsmittelkennzeichen)
namespace QETInformation
    /** Default information related to element **/
    static QString ELMT_LABEL                        = "label";
    static QString ELMT_FORMULA                      = "formula";
    static QString ELMT_COMMENT                      = "comment";
    static QString ELMT_FUNCTION                     = "function";
    static QString ELMT_AUX1                         = "auxiliary1";
    static QString ELMT_AUX2                         = "auxiliary2";
    static QString ELMT_DESCRIPTION                  = "description";
    static QString ELMT_DESIGNATION                  = "designation";
    static QString ELMT_MANUFACTURER                 = "manufacturer";
    static QString ELMT_MANUFACTURER_REF             = "manufacturer_reference";
    static QString ELMT_MACHINE_MANUFACTURER_REF     = "machine_manufacturer_reference";
    static QString ELMT_SUPPLIER                     = "supplier";
    static QString ELMT_QUANTITY                     = "quantity";
    static QString ELMT_UNITY                        = "unity";
    static QString ELMT_PLANT                        = "plant";
    static QString ELMT_LOCATION                     = "location";
    /** Default information related to conductor **/
    static QString COND_FUNCTION             = "function";
    static QString COND_TENSION_PROTOCOL     = "tension_protocol";
    static QString COND_COLOR                = "conductor_color";
    static QString COND_SECTION              = "conductor_section";
    static QString COND_FORMULA              = "formula";
    static QString COND_TEXT                 = "text";
    /** Default information related to diagram **/
    static QString DIA_AUTHOR             = "author";
    static QString DIA_DATE               = "date";
    static QString DIA_DISPLAY_FOLIO      = "display_folio";
    static QString DIA_FILENAME           = "filename";
    static QString DIA_FOLIO              = "folio";
    static QString DIA_INDEX_REV          = "indexrev";
    static QString DIA_LOCMACH            = "locmach";
    static QString DIA_PLANT              = "plant";
    static QString DIA_POS                = "pos";
    static QString DIA_TITLE              = "title";
    static QString DIA_FOLIO_ID           = "folio-id";
    static QString DIA_PREVIOUS_FOLIO_NUM = "previous-folio-num";
    static QString DIA_NEXT_FOLIO_NUM     = "next-folio-num";
    /** Default information related to project **/
    static QString PROJECT_FOLIO_TOTAL     = "folio-total";
    static QString PROJECT_TITLE           = "projecttitle";
    static QString PROJECT_PATH            = "projectpath";
    static QString PROJECT_FILE_NAME       = "projectfilename";
    static QString PROJECT_SAVE_DATE       = "saveddate";
    static QString PROJECT_SAVE_DATE_EU    = "saveddate-eu";
    static QString PROJECT_SAVE_DATE_US    = "saveddate-us";
    static QString PROJECT_SAVE_TIME       = "savedtime";
    static QString PROJECT_SAVED_FILE_NAME = "savedfilename";
    static QString PROJECT_SAVED_FILE_PATH = "savedfilepath";
    /** Default information related to QElectroTech **/
    static QString QET_VERSION = "version";
https://github.com/qelectrotech/qelectr … mation.cpp
https://github.com/qelectrotech/qelectr … ormation.h
