Topic: What is a tag?
Hi there
I'm running QET V 0.90+e3afc562b and Terminal Block Generator v1.3.1.
In the Help for qet_tb_generator it says:
- Terminals must have a tag such as <terminal_block_name>:<terminal_name>.  Etc...
But what is a "tag"?  Where do I find it?  How do I set it?
Many thanks!
John
Re: What is a tag?
Hi John.
tag is the name of terminal block like X11, Input, output, etc
So your terminals to be named X1:1 X1:2 X1:3 X1:4, etc ...
you understand me?
Regards,
Re: What is a tag?
Hi Laurent
Thanks for your reply.  I've been trying to find out exactly what makes it possible for the qet_tb_generator plugin to notice that a terminal exists in a project and include it in the terminal block which it compiles and after much trial and error I think I have discovered it.  Perhaps this is documented somewhere but I couldn't find it so I will write it down here for the benefit of others.
  • construct an element which contains (at least) one terminal and set its Base type to Terminal block (in Edit / Element Property);
  • add (at least) two of these to a folio;
  • make at least one connection between any two of them with a conductor;
  • if for each element the element property Label is given a value which has the correct format (something like <alphanumeric>:<alphanumeric>) then the plugin will find and list that element.
Something odd happens when I call the plugin (using Project/Launch the terminal block creation plugin) - it always throws up the error message box titled "Error launching qet_tb_generator plugin" which details how to install the plugin before it then successfully runs!
Thanks for your work on this project.  I have no experience with such a tool but first impressions tell me that this is a very comprehensive piece of work, well done!
John
