Topic: Check for any double contact used on the project.
Hello people of QE.
Maybe it escapes me and I can't find answers in old posts, and I have a question to ask:
For example, by inserting a telemecanique contactor LC1D... it is possible to have two contacts 13/14 (NO) and 21/22 (NC), plus auxiliary blocks 53/54, 61/62...
Addition of contacts with ref. crossed out and then associating them with the contactor, the program connects them and displays them correctly in the cross at the bottom.
But by numbering them I could be wrong to create two in two different points on the project, is there the possibility of verifying that there are not two contacts (for example 13/14) used at the same time?
thanks for help.
Re: Check for any double contact used on the project.
the connection texts on the contacts, for example 13/14, are simple texts that can be entered directly in the drawing. There is no check when connecting master and slave which contact numbers are already present. It is exactly the same with the labels of an element which can also appear more often in the drawing.
Best regards
Stebo
