Topic: QElectroTech version 0.9 released
https://qelectrotech.org/forum/viewtopi … 250#p17250
====== ChangeLog from 0.8 to 0.9 ======
*Diagram editor :
Improved QElectroTech speed (launch qet, open project, function)
A drop-down list has been added to the toolbar to change the size of the resize handles.
*Element Editor:
The "keep visual rotation" property of element texts is editable from the element editor.
Thanks to the work of antonioaja it is now possible to import a dxf directly from the element editor in a completely transparent way for the user.
In the background QElectroTech uses the dxf2elmt software. https://qelectrotech.org/forum/viewtopic.php?id=2265 https://github.com/antonioaja/dxf2elmt
Improved responsiveness when multiple shapes are selected or deleted, especially when working on a large converted DXF element.
https://qelectrotech.org/forum/viewtopi … 612#p16612
*Other:
Add a "side project" tab in the "about" window.
In the general QElectroTech configuration, a drop down list allows to choose the scaling method for hdpi screens.
Allow open polygons (i.e. polylines) when saving in dxf format.
https://qelectrotech.org/forum/viewtopi … 611#p16611
Added 'Other' option for slave device contact type.
*Logs:
Added a QElapsedTimer to calculate the time used to reload the item collection.
Improved QElapsedTimer to calculate the time used to reload the item collection in seconds instead of ms.
Added Linux pc.gpu.RAM information, but requires mesa-utils dependency on the Linux OS.
Added information about mounted disk volumes.
Added CPU architecture for which Qt was compiled in the aboutqetdialog widget and in the logs.
Added MSVC support to MachineInfo.
Added RAM information on Windows of available RAM.
Added QElectroTech version to the log file.
* Elements collection :
Improve collection 8274 elements in 1097 categories (i.e. 9371 files).
* macOS :
Fix sqlite3 database export on macOS, now I use macports with Digikam scripts instead off Homebrew Package Manager.
See: https://invent.kde.org/graphics/digikam … s/macports
*Bug fix:
see: https://git.tuxfamily.org/qet/qet.git/log/?h=0.8.1
0.9 tarball https://git.tuxfamily.org/qet/qet.git/s … 0.9.tar.gz
Re: QElectroTech version 0.9 released
QElectroTech version 0.90  is now on Debian Unstable, thanks Martin. nomicons/wink
https://buildd.debian.org/status/packag … lectrotech
QElectroTech version 0.90 it 's also available for Fedora ≥ 35 and Enterprise Linux ≥ 8 (RHEL, CentOS, AlmaLinux, RockyLinux...), thanks Remi. nomicons/wink
https://blog.remirepo.net/post/2023/01/ … rsion-0.90
FreeBSD port:
https://www.freshports.org/cad/qelectrotech/
https://www.freshports.org/commit.php?c … d7a3458458
https://www.phoronix.com/news/Debian-12-First-Freeze
Next up in mid-February is the Debian 12 soft freeze where no new packages will be allowed and a delayed migration. One month after that in mid-March is the planned hard freeze.
The full freeze date for Debian 12 has yet to be determined.
Version 0.9 arrives on Fedora 37
Thank you, very good job
Hi Riesermauf,
thank you so much,
but you could also make a big thanks to Remi for packaging QElectroTech in Fedora, RHEL, CentOS, AlmaLinux, RockyLinux... and especially for his help and his many advices. ;-)
QElectroTech 0.90 is now released on Chocolatey software management automation for Windows. (QElectroTech 0.90.7758)
https://community.chocolatey.org/packages/qet
Many thanks to you Erich.
Enjoy! nomicons/wink
