Topic: language not equal to settings
the language setting is english but in "configure Qelectrotech" Appearance
the last item is in French (see picture)
changing to any other language does not change this text
QElectroTech → EN : Help, suggestions, discussions, ... → language not equal to settings
Picture?
picture attached
and here:
Here:
You are using the latest version of 0.9-dev?
I am using the latest version.
But the issue is solved.
As I only replaced the exe file with each new version
There was probably an error in the language files
Also copied the files now all is ok
I tried also on latets 0.9-dev on Windows installe,r translation is fine.
Generated in 0.023 seconds (27% PHP - 73% DB) with 9 queries
