Topic: Language configuration
Hi, I have install and the software was in English but today the software is in another language. I have already try in the configuration change to English and restart the PC but nothing happens. Can someone help me? Thank you.
Re: Language configuration
Windows operating system?
Then you should not start qelectrotech.exe directly.
Use the *.bat file in the root directory.
This bat file contains the start parameters for the application:
@echo off
rem Se rend dans le dossier qui convient
set current_dir=%~dp0
cd /d %current_dir%
rem Met la collection QET en lecture seule
attrib +r elements/* /S /D
rem lance QElectroTech
set command=.\bin\qelectrotech.exe -platform windows:fontengine=freetype --common-elements-dir=elements/ --common-tbt-dir=titleblocks/ --lang-dir=lang/ --config-dir=conf/ LANG=de_DE -style plastique %*
@start %command%
Here the program is started with German language.
